My (D4) is flashing!!!
Old Aug 1, 2004 | 02:15 PM
alicianorris's Avatar
Default My (D4) is flashing!!!
Can someone tell me what I need to do? When I start my car and put it in 1st gear it will not go. I have to manual shift and its a automatic.
Old Aug 1, 2004 | 02:58 PM
Caveman74's Avatar
Default Re: My (D4) is flashing!!! (alicianorris)
What year car? It might be your transmisson going. If it is a V6 then you might be covered under the Honda Warrenty
Old Aug 1, 2004 | 03:02 PM
Accord02's Avatar
I had this same problem when we installed a kill switch through a databus line (ignition) rather than the fuel. No sure if you have a kill switch or not.
Old Aug 1, 2004 | 03:17 PM
Default Re: My (Caveman74)
It is a 1992. In the manual it says D4 indicator light in the instrument panel also serves a second function. If the light flashes while driving (in any gear range) it indicates a possible malfunction in the transmission.
Old Aug 1, 2004 | 03:23 PM
bill-71SS's Avatar
there is a trans controller on that car,it is next to the ecm on the pass. side floor.very common problem for them to go bad.
Old Aug 1, 2004 | 03:26 PM
JDM.Accord's Avatar
Default Re: My (alicianorris)
Yeah, I remember this topic being covered extensively several months ago. Try searching under 'D4' in the archived content. You should get some useful info. Bottom line though, I think your slushbox is about to die
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord02 &raquo;</TD></TR><TR><TD CLASS="quote">I had this same problem when we installed a kill switch through a databus line (ignition) rather than the fuel. No sure if you have a kill switch or not.</TD></TR></TABLE>
What????
Old Aug 1, 2004 | 06:22 PM
Thanks so much for the information. We bought a service manual and a speed sensor. And my husband will be checking out the TCM to see if thats the problem.
Thanks again,
Alicia
TurbobJim
25
Jun 10, 2016 12:17 PM
deejaysmy
May 27, 2016 04:13 PM
moali200
Honda Civic (2001 - 2005)
Jan 16, 2013 03:26 PM
Jay_Mills
Sep 5, 2011 06:50 AM
PriceNation
Jan 14, 2009 04:21 PM
