Zex Purge Install. Wiring Explanation Has Me Spooked. PIC
Old Aug 1, 2004 | 10:16 AM
Full Race A6's Avatar
Default Zex Purge Install. Wiring Explanation Has Me Spooked. PIC
This is exactly what it says in the manual for the zex purge kit install
1.Locate a 12volt source wire and splice into it with the red t tap connector (cant even find this connec). Install the inline fuse holder and fuse on this wire lead and run the remaining length of wire through the hole for the switch. On this end crimp one of the .187 wide female connectors
2.Cut another length of wire and feed it through the same hole, attach the end of this wire lead to one of the solenoid wires using a pair of male/female connectors. Attach a .187 wide female connector to the wire sticking out of the hole.
3.Pull both wires out of the hole
4.Attach .187 wide male electrical connectors to the ends of the push button switch wires and insert the push button switch through the mounting hole. Slide the pushbutton lock washer and lock nut over the wires and thread the nut over the wires and thread the nut onto the switch and tigheten it in place.
5.Connect the switch leads to the wire leads
6.locate the other solenoid wire and connect it to an appropriate ground
WTF DOES THAT MEAN!!
If anyone could just use my diagram and fill in what wire goes where and **** Id appreciate it. Thats ******* confusing.
Old Aug 11, 2004 | 12:27 AM
EF Two.'s Avatar
Default Re: Zex Purge Install. Wiring Explanation Has Me Spooked. PIC (Full Race A6)
Edit: Oops I see this was already answered in the Tech forum.
epicbeats
Jul 29, 2009 12:59 PM
standbackimapro
Audio / Security / Video
Feb 21, 2007 07:38 AM
civic817
Sep 26, 2001 07:10 AM
