problem with corner lights and fuses
sup i got a 95 honda accord and im going threw fuses like a mother ill put one in on the corener light one 15 to be exact and it blows right there as soon as i put it in so i let the car sit over night and put a new on today and it work but the corner light and back lights stay on even after the car is off and the light switch is on off the one next to the stering wheel to the like 5 min later the fuse blows again... ohh i do have an alarm could it be that help plz anyhting would be appreciated.....
Modified by crableg03 at 4:44 PM 1/13/2005
Modified by crableg03 at 9:15 PM 1/17/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E.A. Poe »</TD></TR><TR><TD CLASS="quote">Have you noticed moisture inside of the light housing? If so maybe you are getting a short.</TD></TR></TABLE>
indeed, whenever you blow a fuse like that then there is a short, but you say it worked fine and blew 5 minutes later...have you done any sort of wiring?
installed a system like a year ago but thats it and nothing since then one thing i dont get is the corner lights fuse that control the light and back ones is under the hood and is the fuse for the small light although the book says corner lights the fuse in the car ??????
well best buy unplugged the alarm form the corner lights and the lights still stay on with the fuse in mean while the switch in the car for the lights is on off ... could it mean its broke .. im guesssing i hav eto go to a honda place then ??
test the switch to see if it is stuck open if its in the off position...it should not read 0 ohms...or anything close to it. when the switch is on there should be little resistance...something close to 0 ohms. or you could just check it using the nifty diode check feature...
They probably unplugged it incorrectly because you can't just unplug the corners from the alarm system. There is one wire on the alarm system that gets connected to a white wire under your dash which controls all of your parking lights. So they might have "ghetto rigged" it to bypass the front corner lenses.
alright so some months have past and i still have no idea what it could be i found the problem of the fuse blowig so thats out of the question its just now they still stay on witht he switch on the off possition i even unplugged the harness from the switch on the stering collum and they still stay on
i was told it was a red and black wire so i found it under teh dash and unplugged that form the module that plugs in the switch for the sinals and such and they still stay on wtf
wht do i do is there a way i can make my own switch ... anymhelp would be appercaited tnx in advanced
so in another words i have to take the fuse out every time i go somewherer adn park or theyll stay on
mine was doing the same thing..and someone here on HT suggested if i had any headunit work done lately to check loose wires...
sure enough i had a 7' indash which i didnt quite clean up the wires too well and it kept blowing my fuses...
other than that i couldnt tell you what else to check...
alright so for a good chunck of the day ive been trying to figure this out and still no progress,,, alrigth so today ive un plugged a plug under the dash that leads into the harness for the lights switch and they still stay onn
is therer a way i can make a switch to these lights well the corners im so confussed i mena ive unpluged so many plug and they still stay on
help plz
help plz
Alskee916
Jan 1, 2018 12:38 PM
immajackuup
May 7, 2010 01:00 PM
