wut should i run?
Old Nov 27, 2001 | 11:11 PM
jdmrealm's Avatar
New User
Default wut should i run?
What should my car run with a "pro" driver with 205/45/15 nitto 555Rs in the front on the 1/4mile?
Old Nov 28, 2001 | 04:56 AM
DragII's Avatar
25 Year Member
Default Re: wut should i run? (4g63turbo)
prolly 14s
Old Nov 28, 2001 | 05:24 AM
Chugger's Avatar
Default Re: wut should i run? (DragIIcivic)
id say mid 14's ive heard that the b16 tranny has closer ratios than the gsr and can yield lower times but thats only hear say i havent witnessed but i do know that it does have closer ratios from driving a gsr and si thats my .02
lata
Old Nov 28, 2001 | 06:01 PM
93LSivic's Avatar
Check my sig. My car is a tank of an Si though. Also I am sure that the 555R's might be a little stickier than my yoko's, but I did hit a 2.0 This is with a Gsr trans i/h/e fpr chipped ecu and ignition +2 degrees, rear seats and spare taken out.
Old Nov 28, 2001 | 10:50 PM
jdmrealm's Avatar
New User
Default Re: wut should i run? (93LSivic)
Ill be heading out to LACR next friday..ill post my times. Hopefully Ill break 14s
Old Nov 29, 2001 | 06:30 AM
Suprdave's Avatar
Read my Sig....
1.99 60ft. 14.5@93mph
Intake\Exhaust
Stock Timing\Header\Hi-Flo Cat
~2000 Lbs
20in ET Drags @ 18PSI
Launching @ 5500rpm
Clutchnet Stage 2
B16a Trans (Y1 Cable)
I coulda cut a better 60ft.
Looking for 13.9 with Pulleys\Header\Advanced Timing\Tuned Cam Gears
Before I go Turbo in Springtime that is.
Suprdave
Old Nov 29, 2001 | 06:14 PM
EG8R's Avatar
Default Re: wut should i run? (Suprdave)
Well whatever it is, it's slow.
Old Nov 30, 2001 | 07:05 PM
IWearMyKswiss's Avatar
New User
i think the GSR dash adds like 20 horsepower doesnt it??? hehehe im just playing,..i think a gsr dash in a EG is one of the nicest mods you can do,..i will do the same wen i get my EG,..but to answer ur question...i dont think u will run any faster then 14.5,...good luck
Old Dec 2, 2001 | 12:59 AM
hb_racer's Avatar
Default Re: wut should i run? (WiDeBoDyEK)
with a pro that knows your car, maybe mid 14's. Most likely high 14's and a normal street racer....mid 15's....
Peace
miker01
35
Jul 3, 2006 11:39 PM
EJ8VTEC
Jul 27, 2005 10:45 AM
GSR civicSI prelude4THgen
Jul 30, 2004 01:34 PM
boipika
Mar 31, 2002 04:59 AM
mr2
Dec 16, 2001 03:40 PM
