Reusing ARP studs... does the order matter on which they came from?
Hello-
I took my arp studs out of the block to do some work to it. Does it matter I maintain which holes they came from?
gsr block.
gsr block.
i see no reason why it would make any difference as long as you torque all the bolts down to spec you will be fine
-Brian
-Brian
hello there... i would like to ask u some question about my engine... i've used eg4 1995 d15b soch vtec. i'he change my engine to b16a. can i use b20b block with je low compress piston, toda camshaft type b with toda retainer,stainless steel valve, toda campulley, motec m8 programable ecu, spoon oversize throttle body, to convert my engine to turbo hks gt2835 pro s (internal waistegate). is it suitable for my engine? how many hp my engine can provide? any anti-lag system suitable for my engine?
Modified by firdaus at 11:37 PM 8/1/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboxDC2 »</TD></TR><TR><TD CLASS="quote">i thought that u shouldnt re-used headstuds???</TD></TR></TABLE>
shouldnt reuse head bolts
the ones that came with the motor from the factory.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by firdaus »</TD></TR><TR><TD CLASS="quote">hello there... i would like to ask u some question about my engine... i've used eg4 1995 d15b soch vtec. i'he change my engine to b16a. can i use b20b block with je low compress piston, toda camshaft type b with toda retainer,stainless steel valve, toda campulley, motec m8 programable ecu, spoon oversize throttle body, to convert my engine to turbo hks gt2835 pro s (internal waistegate). is it suitable for my engine? how many hp my engine can provide? any anti-lag system suitable for my engine?</TD></TR></TABLE>
I suggest you make a different topic on this. Click 'new topic' in the upper right of your screen in the appropriate category.
the ones that came with the motor from the factory.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by firdaus »</TD></TR><TR><TD CLASS="quote">hello there... i would like to ask u some question about my engine... i've used eg4 1995 d15b soch vtec. i'he change my engine to b16a. can i use b20b block with je low compress piston, toda camshaft type b with toda retainer,stainless steel valve, toda campulley, motec m8 programable ecu, spoon oversize throttle body, to convert my engine to turbo hks gt2835 pro s (internal waistegate). is it suitable for my engine? how many hp my engine can provide? any anti-lag system suitable for my engine?</TD></TR></TABLE>
it does not matter which hole you took it out from. I would reccommend however run a tap straight through to clean up the threads and make sure everything is correct.
just run a std tap so you clean the threads and also make sure to use some kind of lube when torquing the studs down. I have found many times the studs dont bottom out properly and will not hold. by running a tap through you clean the threads and make sure there is nothign wrong down there its can be costly.
dunkd
Jul 18, 2004 11:10 AM
