Starter problem help ASAp
i just went out to my car and tried to start it and all i hear is the starter trying to turn but it sounds like a remote controld car while its moving and nothing is happeninng any help would be appreciated
Make sure you battery is charged and check all the connections. Also is the battery posts are dirty clean them off. If its not that then go get you started to be checked at a Autozone or something
yep terminals are clean and brand new i have a system in the car ive gone through many batteries and alternators but usually the battery light comes on and stuff ive never had the battery die like this before when i start the car the lights dim if that helps
Look at the engine, look to the left of the valve cover, see the big gray hunk of metal a.k.a the trans, feel in the back for the starter. Its a black component.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Goshenjohn »</TD></TR><TR><TD CLASS="quote">yeah but when its turning it sounds like it isnt catching or something</TD></TR></TABLE>
If your battery is really low on charge it might sound like this also. Almost like a machine gun.
sounds like your pinion gear isnt engaging with your flywheel the soleniod prolly
isnt working id check connections, but i had a problem like that with my type r where my starter was just spining my ring gear around the flywheel.
