venom intake manifold?
It was designed for with FI in mind... The plenum volume is way too much for a mild built street car, the runners are too large (ID) and short to even begin to make power in a usable rpm range... Id only recomend something like the STR IM on a turbo car or a 2.5+ motor that will see rev's in the 9K range
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznBlueBoy »</TD></TR><TR><TD CLASS="quote">would it be good to have this manifold with bolt on's and a port polished head with oversized valves and crower stg 2 cams?
or still not good enough?</TD></TR></TABLE>
Youd need to be in the 2400cc+ range and have a peak of around 9000...
Not good at all for a 2.2-2.3 NA set up...
Modified by Rick Solis at 6:10 AM 8/1/2004
I agree with Rick. More displacement and/or running hi compression pistons 13:1 or higher would make that manifold worth while. It's a boost manifold.
We've created more volume out of the stock manifolds by completely milling out the 8 ports (4 IAB and 4 regular runners) into 1 big plenum. This would be similar to the SK2 B series and H series designs.
