claybar cf hood
Old Jul 31, 2004 | 04:34 AM
NewBorn_EG's Avatar
Default claybar cf hood
i was wondering if it ok to claybar my cf hood cause it feels gritty and washing it didnt do anything .i searched for it to but i couldnt find it ..if anyone posted up let me know.
Old Jul 31, 2004 | 05:19 AM
jerbear!'s Avatar
yes.
Old Jul 31, 2004 | 05:31 AM
Luserkid's Avatar
Default Re: (jerbear!)
Whats Claybar?
Old Jul 31, 2004 | 12:34 PM
NewBorn_EG's Avatar
thank you
Old Jul 31, 2004 | 12:37 PM
Sliced Beard's Avatar
Default Re: (jdmEFnine1)
yes you can clay bar your cf hood
Old Jul 31, 2004 | 12:46 PM
rodrez.'s Avatar
Default Re: claybar cf hood (jdmEFnine1)
When I used a cf hood, I probably did it 3 times a year, with no problems.
Modified by rodrez at 4:00 PM 7/31/2004
Old Jul 31, 2004 | 12:47 PM
asmallsol's Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Whats Claybar? </TD></TR></TABLE>
its basicly exactly what it sounds like. It is a detailing product that is a special kind of clay, and you rub it on your car with detailing spray for lube, to get very small contaminets off your paint, expessailly before you wax. It will make the paint become extremly smooth. There are little kits that comes with clay and spray, for &lt;$15. I have used Mothers and Clay majic now, and I like the clay majic better, plus it is a tad cheaper.
Old Jul 31, 2004 | 01:08 PM
Pworld's Avatar
From: somewhere in INGLEWOOD chillin in tha hood, CA
Default Re: (asmallsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asmallsol &raquo;</TD></TR><TR><TD CLASS="quote">
its basicly exactly what it sounds like. It is a detailing product that is a special kind of clay, and you rub it on your car with detailing spray for lube, to get very small contaminets off your paint, expessailly before you wax. It will make the paint become extremly smooth. There are little kits that comes with clay and spray, for &lt;$15. I have used Mothers and Clay majic now, and I like the clay majic better, plus it is a tad cheaper.</TD></TR></TABLE>
Its basically like color sanding with a high grit sand paper, make simple and marketable for us consumers
Old Jul 31, 2004 | 01:46 PM
NewBorn_EG's Avatar
Default Re: (Pworld)
where can i find it i just came back from autozone and they dont have it .
Old Jul 31, 2004 | 01:49 PM
=GAME='s Avatar
yes it will work but wetsanding and buffing would give it a smoother and a more glossy finish. Also if you have a friend in a bodyshop, you could wetsand, then ask him to spray a few layers of clear and then wetsand and buff for a better result.
Old Jul 31, 2004 | 01:50 PM
=GAME='s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmEFnine1 &raquo;</TD></TR><TR><TD CLASS="quote">where can i find it i just came back from autozone and they dont have it .</TD></TR></TABLE>
they should have it at any place that sell paint, compounds and buffing stuff.
Old Jul 31, 2004 | 01:55 PM
NewBorn_EG's Avatar
Default Re: (=GAMEOVER=)
not to many paint places here ..i will have to check pepboys ..
Old Jul 31, 2004 | 02:21 PM
Jammersplace's Avatar
would it help with scratches on the cf like from sand out here in cali
Old Jul 31, 2004 | 04:57 PM
asmallsol's Avatar
Default Re: claybar cf hood (Jammersplace)
no, claybar basicly only gits little grit that builds up. Like if you get water spots that won't wash off, claybar is what you need.
For those little scratches, first try rubbing compound, and if that doesn't work, wet sand with something like 1500 grit and if that doesn't work, keep going down in grit. However, once it does get it out, then you need to work your way up with finer grits (all doing wet) until it becomes extremely clear.
Old Jul 31, 2004 | 05:20 PM
RedlinedVTEC's Avatar
Default Re: claybar cf hood (asmallsol)
I work in a detail shop and in most cases clay bar won't remove water spots completely. We Use an acid that is safe for the clear to remove them. Works on glass too.
Old Jul 31, 2004 | 05:22 PM
asmallsol's Avatar
Default Re: claybar cf hood (RedlinedVTEC)
wouldn't you want to use a bace to remove water spots to balance the PH?
Old Jul 31, 2004 | 05:29 PM
dinosa21's Avatar
works on glass. What is this magic acid. My window looks like crap with all these spots.
Old Jul 31, 2004 | 07:08 PM
mnbv's Avatar
Default Re: claybar cf hood (dinosa21)
Get a window polish, also check out autopia.org for all of your detailing needs.
Old Jul 31, 2004 | 09:30 PM
Jimmy's Avatar
Global Moderator
damn..
sounds like a good idea
I seen a few posts but where can you pick it up at and average price?
Is there a DIY?
redDAinteg
Nov 10, 2005 06:01 PM
imonx850
Oct 12, 2005 07:55 PM
msTEGGY
Jul 16, 2004 02:39 PM
crazy_ham
Feb 4, 2004 10:24 AM
wm5holla
Jan 24, 2003 08:12 PM
