Rear disk brake swap questions
I have an 88 DX 4dr and thinkin about doing a rear disk swap. Along with all the parts in the back, what else is needed?
40/40 Prop valve from ??
15/16 MC from a DA??
Brake booster???
If anyone can give me more info (specific to my car) i'd appreciate it.
Thanks!
Brake booster???
Thanks!
Mod or not, no info then don't post
-Sergio, who hopes his thread doesn't get locked now lol. I'll try searching more tomorrow
OK searched and found info on most parts needed. I plan on using the CRX rear disc or 90-93 teg rear disk, BUT i also plan on doing the front OEM upgrade with the 90-91 EX knuckles etc.
So what I still couldn't find was which car has a 15/16 MC that will bolt right up to my 88 DX sedan and also do i need to switch the brake booster?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMZ GSR »</TD></TR><TR><TD CLASS="quote">OK searched and found info on most parts needed. I plan on using the CRX rear disc or 90-93 teg rear disk, BUT i also plan on doing the front OEM upgrade with the 90-91 EX knuckles etc.
So what I still couldn't find was which car has a 15/16 MC that will bolt right up to my 88 DX sedan and also do i need to switch the brake booster?</TD></TR></TABLE>
Man, all you need to do is type in "rear disc", click on archives, select the EF forum and you'll see tons of info.
If it helps, I used a 90-91 Teg MC and BB, works great on my 88 dx.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">
Thing is I'm also planning on switching the front as well. A lot of people mention the MC but almost no one talks about BB.
</TD></TR></TABLE>Thing is I'm also planning on switching the front as well. A lot of people mention the MC but almost no one talks about BB.
coot_er
17
Jan 27, 2007 11:22 AM
JSTOCK
Feb 25, 2002 08:13 AM
