d16z6 head+d16y7 block equals what comp ratio?
im using this for a boosted app.with this comp ratio,would you know what comp ratio pistons i would need for around 9:1?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictypenos »</TD></TR><TR><TD CLASS="quote">d16z6 head+d16y7 block equals what comp ratio?
im using this for a boosted app.with this comp ratio,would you know what comp ratio pistons i would need for around 9:1?</TD></TR></TABLE>
I believe it would be less than stock, because the z6 combustion chamber is larger
another question.....this is for a 90 crx,we put the 97 y7 in it with no problems concerning the distributor,it bolts right in.now with the z6 head,the distributor doesnt match up.what an i do?can i get a 92-95 distributor and change out the casing for the obd0 wiring?or just modify the existing dist.?
http://www.knology.net/~jediklc/D.htm
After checking here, it seems the CC of the z6 and y7 heads are the same, so compression should stay the same.
About the distributor, this is why I always advise against using a z6 head in an OBD-2 car. No OBD2 dizzy will directly bolt onto a z6 head. You can either modify the distributor mounting holes or you can swap the guts, and I am not experienced in either.
its actually for a 90 crx,the 90 dist fit perfectly in to the 97 head,go figure.but now with the z6 head,i dunno what route to take yet??lol.
yz125rider21
Jan 11, 2006 09:39 AM
added, block, blockz6, change, compression, d16y7, d16z6, distributor, fit, head, puting, ratio, statistic, statistics, stock
