When getting a OBD2-OBD1 car inspected.....?
Old Jul 30, 2004 | 09:23 PM
-1TSXer-'s Avatar
Default When getting a OBD2-OBD1 car inspected.....?
When getting a car inspected (2000 Civic Si) with an OBD2 to OBD1 conversion will it pass the OBD2 input inspection. I've heard mixed comments and was curious as to what is true. No sniffer test here in Texas only visual and OBD connector test. thanks in advance
Old Jul 30, 2004 | 09:40 PM
IVI's Avatar
IVI
Default Re: When getting a OBD2-OBD1 car inspected.....? (-CivicTuner-)
i dont know about texas, but in new jersey it will not, all cars 1996 i believe and higher must be plugged into the comptuer to read any computer error codes. over here if your cars a 96+ and u have obd1 , i think its pretty tough to get an inspection.
Old Jul 31, 2004 | 09:01 PM
B9000rpm's Avatar
you need the obdII plugged in to pass in Illinois.
Old Jul 31, 2004 | 10:28 PM
v4lu3s's Avatar
RTFM
going strictly by the law you will fail, the obd1 ecu will not reply to the obd2 scan tool, so it will show as all sensors failed. if you are lucky they will run an sniffer test ratehr than jstu fail you.
why n tjsut slap your stock obd2 ecu back in and pass???
Old Aug 1, 2004 | 07:25 AM
-1TSXer-'s Avatar
Default Re: (v4lu3s)
that's probably what I'm going to have to do. just wanted to save the hassle. thanks for the responses
GS-Racer X
Engine Management and Tuning
Jul 16, 2009 06:17 PM
technine
Apr 30, 2009 07:12 PM
96MidoriHatch
10
Mar 7, 2005 06:11 PM
xXx Justin xXx
May 17, 2003 10:55 PM
MeanGreenEG9
Dec 4, 2002 11:16 PM
