Broke a chunk off my tranny.
Old Jul 30, 2004 | 08:13 PM
Andres-eh2's Avatar
Default Broke a chunk off my tranny.
This is my GSR tranny. Happened at the track. How bad is this? Can this tranny see the track again. Doesnt seem to be leaking :fingers crossed:
Old Jul 30, 2004 | 08:15 PM
Draggin99Si's Avatar
Default Re: Broke a chunk off my tranny. (Andres-eh2)
What the hell happened? Did you hit something?
Old Jul 30, 2004 | 08:17 PM
handa's Avatar
damn it looks pretty chipped off!
you might be able to drive it around, but definitely not on the track just to be on the safe side. weld it back on?
Old Jul 30, 2004 | 08:19 PM
ABK's Avatar
ABK
Default Re: Broke a chunk off my tranny. (handa)
you can take it off and take it to machince shop or weld shop or whatever. and have them weld the hole shut, drilled and retapped. But it has to be a good welder.
Old Jul 30, 2004 | 08:32 PM
hondainspired's Avatar
Default Re: Broke a chunk off my tranny. (ABK)
lol..thats crazy...
Old Jul 30, 2004 | 08:33 PM
Andres-eh2's Avatar
i was thinking maybe, fill the whole thing with like jb weld and tap it?
Old Jul 30, 2004 | 08:34 PM
Tad's Avatar
Tad
well that is where the tranny mounts to the block,
its not going to leak because there is nothing in there to leak out.
theres just the clutch in there and clutch fork.
have to wonder how the ****??
how about ya tell us meeyybe?? hehe
Old Jul 30, 2004 | 08:37 PM
ABK's Avatar
ABK
Default Re: (Tad)
I think it was overtoqued, prolly with an impact or something or other bolts were too loose and after alot of launches it finally decided to break.
Old Jul 30, 2004 | 08:38 PM
MickeeFREE's Avatar
Default Re: (Tad)
thats the rear mount right??? my buddy did that to his tranny also...
did u happpen to have the other tranny mount??
my buddy shifted so hard... and BLAM.... took a chunk...
Old Jul 30, 2004 | 08:39 PM
Andres-eh2's Avatar
it all happend at the track. first the motor shifted so much that the linkage slipped out from the bushing
( https://honda-tech.com/zerothread?id=941664 ) then i look today and i see that **** cracked. i did here the bolt go flying btw. i wanna look for the piece maybe it went with the bolt
Old Jul 30, 2004 | 08:40 PM
Andres-eh2's Avatar
i have all the other mounts
Old Jul 30, 2004 | 08:53 PM
Madspeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 &raquo;</TD></TR><TR><TD CLASS="quote">This is my GSR tranny. Happened at the track. How bad is this? Can this tranny see the track again. Doesnt seem to be leaking :fingers crossed:
</TD></TR></TABLE>dude i had the same thing happen to a swap i put in for a friend....GSR torque rules!!!!!!!!!!!!!!!!!!
Old Jul 30, 2004 | 09:03 PM
Andres-eh2's Avatar
you mean LS torque. Thats what i got. How does it drive with just one bolt on the side btw?
Old Jul 30, 2004 | 09:06 PM
ABK's Avatar
ABK
Default Re: Broke a chunk off my tranny. (Madspeed)
yeah I would check for the damage on the block too, and I would get the tranny welded and retapped asap because you could break everything else on it. You could also look for GSR tranny bellhousing, I don't know if all b series belhousings are the same.
Old Jul 30, 2004 | 09:10 PM
Andres-eh2's Avatar
why damage on the block?
Old Jul 30, 2004 | 09:15 PM
Madspeed's Avatar
Default Re: (Andres-eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 &raquo;</TD></TR><TR><TD CLASS="quote">you mean LS torque. Thats what i got. How does it drive with just one bolt on the side btw?</TD></TR></TABLE>
damn dude we did it with a GSR..... still a daily driven car with the bolt missing driven HARD and no trouble yet.....but Honda put that bolt there for a reason.
Old Jul 30, 2004 | 09:26 PM
ABK's Avatar
ABK
Default Re: (Madspeed)
well I'm not sure, I know that bolt goes thru either mount to the tranny or thru the block to tranny or maybe thru both. Well the other side of bolt had to come out somewhere so I would check fo it.
Old Jul 30, 2004 | 09:28 PM
Andres-eh2's Avatar
that bolt itself goes through the bracket and to the tranny.
Old Jul 30, 2004 | 09:58 PM
the_0ne's Avatar
Here is mine, YOU CANT repair it, you must get a b-series bellhousing casing, than transfer all your gears to that casing and reseal it. I had a machine shop do mine.
Mine broke, because the bolts were stripped, so they werent never really tighten down, than my rear mount broke.
good luck man, i feel for you
Old Jul 30, 2004 | 10:01 PM
ABK's Avatar
ABK
Default Re: (the_0ne)
oh yeah your rear mount might be shot as well as your L mounts. I think it caused your shifter bushing to slip out along with braking your tranny.
Old Jul 30, 2004 | 10:11 PM
hatchi's Avatar
arent there 2 bolts for the rear bracket??
Old Jul 30, 2004 | 10:14 PM
BauleyCivic's Avatar
Risky Business
Default Re: (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">arent there 2 bolts for the rear bracket??</TD></TR></TABLE>
Theres 3...two for the trans, one for the motor
Dude that bellhousing is done, my slave cylinder bolt hole was cracked so I jbwelded a stud in there and it works fine, but that is not something you want to jb weld. Get a new bellhousing or new trans altogether if you wanna keep racing...
Old Jul 30, 2004 | 10:22 PM
743power's Avatar
Default Re: (BauleyCivic)
you guys give up too easy. You can fix that with some aluminum scrap, a drill, a tap and die set, and someone who knows how to weld aluminum
Old Jul 30, 2004 | 10:26 PM
t25hatch's Avatar
it is important that when you weld on it you keep as little heat as possible, because it can warp very easily
Old Jul 30, 2004 | 10:27 PM
Nerologic's Avatar
mine was WORSE and i fixed it , after constant thrashin at 12psi my tranny went out (motor went out soon after ). All 3 bolts were stripped and the back 2 chucks snapped off first it was a crack then eventually a chunk came out i paid 100 bucks to get this tranny and another welded. all i had to do was shave it down flat tap it and i was back on the road.
