Does your caR pop out of gear like this??? Vid
Could be many different things causing that.. Linkage could be bent, internal trans problem, or some other things.. Check out the linkage 1st of all and make sure everything is adjusted right and it is not damaged.. Good Luck.. My 2 cents...
Kevin
Kevin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">Its probably something bent, I only notice it when making left turns, track or street, fast or slow.</TD></TR></TABLE>
very strange
very strange
I could be just doing the slow cruise around the hood and next thing I know I'm in neutral
sometimes with very light application of gas it pops out, and sometimes it just pops like in the video and won't stay in untill I get the car striaght or slow down
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 »</TD></TR><TR><TD CLASS="quote">the clutch is impossible to use
hehee
</TD></TR></TABLE>hehee
Motor mounts, what are they???
I guess your saying that I might need them?
Cause your right, I can by hand move the motor 4inches front and backwards
One day... I'll fix them
I know its a long shot, but make sure you have enough tranny fluid.
My friend didn't think to fill the tranny up after receiving it from Hmotors and the car was popping out of gear all day long. After hours of trying to figure out what was wrong, I asked it he filled it with fresh fluids, and low and behold he was a dumbass.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lynx »</TD></TR><TR><TD CLASS="quote">I know its a long shot, but make sure you have enough tranny fluid.
hes lucky he didnt destroy the tranny.
</TD></TR></TABLE> hes lucky he didnt destroy the tranny.
Oh that's normal.
See the tranny has a built in torque sensing solenoid. When it senses that it has too much mad vtec torque, it pops the car out of gear to avoid damaging the transmission.
