Cold air intake???
Old Jul 30, 2004 | 04:07 PM
SeanBoy's Avatar
Default Cold air intake???
I live in Vancouver Washington, it rains a lot here and im worried about water getting sucked up by a cold air intake, is it a good idea???
Old Jul 30, 2004 | 05:29 PM
spyz34's Avatar
Default Re: Cold air intake??? (SeanBoy)
Well AEM has a thing called a bypass valve. If i lived in Washington though I would probably just stick with short ram.
http://www.aemintakes.com/
Try that it should help with your question. Oh and next time try the search function. You can find a ton of **** with it.
https://honda-tech.com/zerothread?id=749544
Old Jul 30, 2004 | 05:55 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Cold air intake??? (spyz34)
i agree with you i'd just use a short ram in that area even though that bypass valve is very sweet
Old Jul 30, 2004 | 06:49 PM
spyz34's Avatar
Default Re: Cold air intake??? (Ace$nyper)
It is sweet, but i have heard of some having problems. Not for sure, but im sure if you searched youd find it.
Old Jul 30, 2004 | 07:46 PM
gac_gonejeepin's Avatar
heard that the aem bypass only works if the intake has been submerged in water, does little to nothing for splashes or partial suction...it would worry me too much. run the short ram.
--gabriel
Old Jul 30, 2004 | 08:08 PM
GetCaughtDead's Avatar
I've got one, but I figure that as long as your plastic inner fender is intact, that should be enough to protect you from the spray from your wheels. If you see a really *big* puddle, go around it. I haven't had any problems yet.
Old Jul 30, 2004 | 09:08 PM
1badcrx's Avatar
If you really have your sights set on a cold-air system then all you need is a by-pass valve. It takes care of all your problems, concerning water. Yet you will have to fork out some change, because the system itself is not cheap.
Old Jul 31, 2004 | 07:25 PM
hatchback_al's Avatar
Default Re: Cold air intake??? (1badcrx)
Are you joking, its just a little filter that goes before the cold air extension, they are 30 bucks at most
egzo04
Sep 8, 2005 10:22 AM
LAKER HATER
Apr 26, 2004 10:42 PM
Jaypee
Dec 8, 2003 11:39 PM
bowhunter
May 26, 2003 04:41 PM
p0pe
Apr 18, 2002 12:02 PM
