Changing to an aftermarket radiator
Old Jul 30, 2004 | 03:25 PM
Draggin99Si's Avatar
Default Changing to an aftermarket radiator
My car is almost due for a coolant flush, and I figured it would be a good opportunity to go ahead and swap to a more efficient aftermarket radiator. How difficult is it to install a new radiator?
Old Jul 30, 2004 | 08:16 PM
Default Re: Changing to an aftermarket radiator (Draggin99Si)
Bump for the nite owls
Old Jul 30, 2004 | 08:22 PM
handa's Avatar
very easy.....unless it's a hard fit, and you'll have to do custom fit.
-take off the radiator cap. get an oil pan or something under radiator and unscrew the screw on the bottom of it to drain it all the coolant out.
-there should be 2 hoses (top and bottom) of it. unclamp and take those out
-the rest should be simple bolts and plugs for the radiator and fan that you'll have to take out.
there was a good thread on step to step howto do this....let's see if anyone can find it before me...
EDIT:
https://honda-tech.com/zerothread?id=794765
Old Jul 30, 2004 | 08:32 PM
Default Re: Changing to an aftermarket radiator (handa)
thanx
Old Jul 30, 2004 | 08:34 PM
ABK's Avatar
ABK
what car and engine do you have, and is the radiator a stock piece?
Oh yeah the whole club SI is really gay, lol.
Old Jul 30, 2004 | 08:36 PM
Default Re: Changing to an aftermarket radiator (ABK)
99 Si, factory B16, factory radiator
Old Jul 30, 2004 | 08:43 PM
ABK's Avatar
ABK
lol leave it, it's more then enough to cool anything. Unless you are going to be boosing and making serious I mean serious amounts of power, you won't need to get different radiator. You already got a dual core radiator it's not worth wasting your money on something that you don't need. Just flush and refill, and spend the money on something else.
Old Jul 30, 2004 | 08:45 PM
I'm slowly prepping it for a supercharger, and I will not skimp on cooling.
Old Jul 30, 2004 | 08:49 PM
ABK's Avatar
ABK
believe me you are still going to be fine, even with supercharger. I would say that radiator is good for 300hp+
lmike6453
Oct 14, 2008 02:03 PM
vxtirent08
Mar 20, 2008 10:36 AM
aasaa666
Oct 22, 2007 08:15 PM
tkHBseries
Feb 19, 2005 06:48 PM
EGh22aEG
Jan 9, 2002 06:37 PM
