Need some help evaluating a questionable leakdown test result
Old Jul 30, 2004 | 01:44 PM
Ill's Avatar
Ill
Default Need some help evaluating a questionable leakdown test result
Had 1141 in for a checkup. Part of that included compression and leakdown to see how she's faring as the miles go on (daily VTEC).
Compression is still **** at 220-220-224-220 (10K since last valve adjust). However, mech said leakdown was 'perfect' (none) on 2 & 4, but losing 'a little' on 1 & 3. I pressed for details, but didn't get a rate (e.g. # of pounds down in x amount of time). He said he could hear it escaping through the intake on 1 & 3, and it was not holding it too long. Uh oh.
Based on HT searches, is 5% spec for B18C5?
:edit: I'm guessing the guy I talked to did not run the test, and does not know much. Maybe it wasn't bad, so they didn't give specifics. I'll go hit the owner back Monday and demand to know what's going on, then either get a re-test, or my money back. Ha Ha, leakdown and no %. WTFE. These guys must just be consumed with work, they are really slipping. They used to be good.
Modified by Ill at 9:29 AM 7/31/2004
Old Jul 30, 2004 | 08:27 PM
Ill's Avatar
Ill
Default Re: Need some help evaluating a questionable leakdown test result (Ill)
N E one? How fast should the R leak down, and is there any issues with 1 & 3 vs 2 &4?
Old Jul 30, 2004 | 08:41 PM
Bbasso's Avatar
I dred the day I have to do this to mine...
I wish I could help, but I don't know much about leakdown testing.
G0od luck!
Old Aug 8, 2004 | 04:22 PM
301am's Avatar
leakdown test takes about an hour give or take a bit...i dunno bout 1/3 vs 2/4
niterider96cord
Jun 22, 2010 07:46 PM
humboldt_skim
May 31, 2008 08:18 AM
( o )( o )
Sep 21, 2005 04:20 AM
Azcheron
Jun 23, 2005 09:34 PM
AdamITR
Jul 22, 2002 01:32 AM
