What is this green crap?
Old Jul 30, 2004 | 01:22 PM
Jonathan_ED3's Avatar
Default What is this green crap?
Was cleaning out my evaporator, went inside for a bit, and when I came back out this green stuff was dripping out of the smaller tube.
Focus on the smaller tube (don't know the exact name), it's like a neon green (antifreeze color) oily substance.....and no, it's not antifreeze
Is this just oil? Or is it a sign of something bad?
Additionally....is there a way to tell if an evaporator is still good or not without having the a/c system hooked up?
Old Jul 30, 2004 | 01:23 PM
APEX CRX's Avatar
Default Re: What is this green crap? (Jonathan_EH)
maybe some dye used for leak check? Not sure you would be able to check it wituout it hooked up. ??
Old Jul 30, 2004 | 01:25 PM
egchan's Avatar
its leak dye. to see if the ac system has a leak, the dye would show up in uv light with special glasses.
EL Vap133's Avatar
Did your AC work before? Is the green stuff on the outside as well?
Old Jul 30, 2004 | 01:26 PM
APEX CRX's Avatar
Default Re: What is this green crap? (SlickCRX)
damn, you don't even need any uv light for that stuff . its god damn flourescent
Old Jul 30, 2004 | 01:27 PM
egchan's Avatar
was there a problem with the ac before? if not your'e evap is probably fine. if it wasn't the dye would actually show up on the seams or something indicating a leak.
Old Jul 30, 2004 | 01:28 PM
egchan's Avatar
Default Re: What is this green crap? (APEX CRX)
under the hood you would. it barely shows up though cracks .
Old Jul 30, 2004 | 01:39 PM
I bought the car without the a/c system. Everything under the hood was gone.
All the interior crap was still there...evaporator, switches, wiring etc.
The evaporator lines were left open at the firewall.
I'm cleaning EVERYTHING up since I had it all apart to do wiring and I'm just trying to figure out if the evaporator is good or not.
If it's not, I'd like to go ahead and get it replaced while everything is apart, but it is an expensive item and I don't want to have to shell out any money if I don't have to.
piineapple
11
Nov 27, 2013 12:06 PM
src185
Honda Civic (2001 - 2005)
Aug 16, 2011 05:12 PM
GraphiteMW
Sep 20, 2006 08:26 PM
grtek
May 18, 2006 12:29 PM
mickey513
Feb 25, 2004 12:07 PM
