Swapping out d16z6 for d15z1 how wll it run?
Old Jul 30, 2004 | 12:50 PM
_BEN_'s Avatar
Default Swapping out d16z6 for d15z1 how wll it run?
I will be swapping out my d16z6 out for a d15z1 soon so I can build the d16z6 for boost. (project smog legal ninja coming soon!!)
Assuming that the z1 is in proper working order. Will this engine operate ok for an a-b car for about 1~2 months. I plan on using all of the d16z6's harness, sensors, and ecu.
Thanks.
Old Jul 30, 2004 | 05:12 PM
_BEN_'s Avatar
Default Re: Swapping out d16z6 for d15z1 how wll it run? (_BEN_)
I think the only two things that will be different for the z1 is a o2 sensor and the ecu.
Anyone know?
Old Jul 30, 2004 | 06:24 PM
BauleyCivic's Avatar
Risky Business
I hope you plan on using the transmission from the Z6...
Old Jul 31, 2004 | 10:09 AM
_BEN_'s Avatar
Default Re: Swapping out d16z6 for d15z1 how wll it run? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">I hope you plan on using the transmission from the Z6...</TD></TR></TABLE>
Why is that? I was planning on slapping the vx tranny in there too so I can tear down the one in my si and put a lsd int it and maby steel shift forks.
Old Jul 31, 2004 | 10:18 AM
thursday's Avatar
Its just the z1 tranny is so long geared that it makes the car not fun to drive. A long time ago i saw a diagram vx to si wiring...but i think the only differences are the ecu and the o2 as well, you have to change some wires on one plug on the firewall or something?
Old Jul 31, 2004 | 10:33 AM
_BEN_'s Avatar
Default Re: Swapping out d16z6 for d15z1 how wll it run? (Melted)
Thanks for the replys guys.
I dont really care if the car is fun to drive. Just as long as it gets me to work for the month or so it will be in my car. Then I will take it back out and sell it or something.
Old Jul 31, 2004 | 12:02 PM
Jokerluv's Avatar
only diff is a different ecu, the z1 has an egr system
but will work till you get your rebuild done
Old Jul 31, 2004 | 12:04 PM
v4lu3s's Avatar
RTFM
egr system and 5 wire o2 sensor will make the diff...
kyle.kouns
16
Dec 7, 2008 05:00 PM
CapnKrunch
10
Jun 15, 2007 06:25 AM
B16 IIgen
Oct 26, 2006 04:34 PM
posterfee
Jan 12, 2006 07:54 PM
nekoabandoned
13
Dec 2, 2005 10:05 PM
