clarification: (walbro high pressure 255) vs. (walbro 255) pumps. what's the actual difference?
what is the difference exactly? specific situation here is going boost, using an AEM FPR and dsm 450s with a VAFC. so...the fpr just makes sure that the fuel being delivered to the injectors isn't at too high of a pressure. so is there a benefit to the high pressure fuel pump or not? is it kind of a range situation, where the HP version is just build sturdier so it can handle higher pressures, or does it deliver it at a higher pressure all the time...?
and don't just say higher pressure is better, because you'd be wrong.
http://www.hondata.com/techfuelpump.html
Boom = > http://www.autoperformanceengi....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur »</TD></TR><TR><TD CLASS="quote">Boom = > http://www.autoperformanceengi....html</TD></TR></TABLE>
So basically if you're running 60 psi + then you should get the hi-pres walbro 255?
I didn't even know walbro made a hi-pres 255.
I going to see the guy i bought it from tomorrow and see what's up.
Or...http://www.lightningmotorsport...h.htm and good deals for HT members... https://honda-tech.com/zerothread?id=298292
Tom
Tom
MtnCRX
May 7, 2005 01:52 PM
turboH22Aakkord
Jun 24, 2004 11:28 AM
