TURBP QUESTION
you might want to consider a different fuel management rather than using that FMU.
injector wise you might need better injectors that the stock ones.
you might want to check out the force induction forum or http://www.homemadeturbo.com
you could run 30lbs but it wouldn't last 1 minute...
I'm guessing your looking for safely runm I'd say no more than 10lbs unless you want to build up your bottom end. It's better to be safe than sorry, so I wouldn't push it
