tein flex...pillow ball mounts??
hey im gonna order some tein flex's whihc include pillow ball upper mounts...is this gonna be a big problem for the street?? my car is daily driven
well im not purchasing them seperate because i know thwey arent needed...they are included with the flex's...im jw if its gonna be a problem on the street
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22HATCH »</TD></TR><TR><TD CLASS="quote">Not a problem at all. I've been rockin the Flex's for almost 2 years now</TD></TR></TABLE>
i rock the super streets... best investment ive made on my suspensions.. once u drive with them, then u drive a stock friend's car or suttin, youll notice the difference.. i usually turn fast and i dont feel the G force from turnin.. but when i drive my boy's car and turn the same speed, u feel all of it.. go flex or super street and use your stock pillow ball mounts.. you wont regret it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JinDIESEL »</TD></TR><TR><TD CLASS="quote">
im a little confused...u DO have pillow ball mounts...or u DON'T? I plan on either getting the flex's or the super streets...but the flex's have higher spring rates
im just a little concerned about the pillow ball mounts giving too rough of a ride on the street
</TD></TR></TABLE>im a little confused...u DO have pillow ball mounts...or u DON'T? I plan on either getting the flex's or the super streets...but the flex's have higher spring rates
Yes they come with pillow ***** ! my set did. and if you look on
http://www.tein.com/flexdamp.html
* Full-length adjustment and height adjustment for separate setting of the height and spring preload.
* 16 levels of damping force adjustment (compression and rebound together).
* Teflon coating for rust prevention.
* Newly designed spring seat and spring seat lock for easy height adjusting.
* Pillow ball upper mounts are included. <---- right there
* Compatible with EDFC.
* Available for overhaul.
alien
Suspension & Brakes
29
Jun 19, 2006 05:47 AM
Mike D
Mar 6, 2002 01:34 PM
