compression test
Old Jul 29, 2004 | 08:37 PM
the.hamburglar's Avatar
Default compression test
what is the worst that would happen if you do a compression test and crank it over while the tool is and you dont disable the distributor. can you fry your ecu???
Old Jul 29, 2004 | 08:41 PM
RedlinedVTEC's Avatar
Default Re: compression test (hamburgler)
No that would not happen.
Old Jul 29, 2004 | 10:11 PM
Default Re: compression test (RedlinedVTEC)
well what would happen? anyone?
Old Jul 29, 2004 | 10:15 PM
hondaeg8's Avatar
why would you disable the distributor? you just need to take the ecu fuse out.
Old Jul 29, 2004 | 10:28 PM
Default Re: compression test (hondaeg8)
yeah what if you dont take the fuse out..... and turn it over....?
Old Jul 29, 2004 | 10:32 PM
B16Drag's Avatar
well did you try it and now your car doesnt start at all or is this some hypothetical question?
usuallly when doing compression testing you just pop off the ecu fuse and then do the compression testing with the gas pedal floored to open the TB
Old Jul 29, 2004 | 10:36 PM
Default Re: (B16Drag)
yeah this is what i did, i didnt take out any fuses or anything, just bought the tool and then turned er over, now my ecu wont even throw a code. in the dizzy harness the orange wire CYP senser was black (female end on the clip)
Old Jul 29, 2004 | 10:38 PM
hondaeg8's Avatar
Default Re: (hamburgler)
don't know...never done it that way before
Old Jul 29, 2004 | 10:39 PM
i actually purposly tried throwing a code by pulling a wire out of the 02 senser, i had this happen when i got new exhaust. the wire just came loose or something and threw a code so i just pushed it back in.
Old Jul 29, 2004 | 10:40 PM
hondaeg8's Avatar
i don't think anything would happen. when you turned it over , did your car start up?
Old Jul 29, 2004 | 10:41 PM
civicdragger818's Avatar
To be honest I have never even pulled the ECU fuse. This type of test to the best of my knowledgs has nothing to do with the ECU. Someone correct me if I am wrong but you have F..ked something up.....
Old Jul 29, 2004 | 10:42 PM
Default Re: (hondaeg8)
nope, i did my compression test and didnt take out any fuses, now my car wont start
Old Jul 29, 2004 | 10:43 PM
yeah and im trying to figure it out. i bought a new dizzy and that doesnt work. ihave feul, no spark.
Old Jul 29, 2004 | 10:44 PM
hondaeg8's Avatar
check all your fuses to see if you blew any.
Old Jul 29, 2004 | 10:45 PM
no blown fuses. i have check absoluty everything. i just dont get a code from the ecu, so i figure its fried
xJDMCx
May 29, 2009 06:10 PM
ge_itr
Aug 13, 2006 08:14 AM
sheBangZ
Oct 21, 2005 03:46 PM
EM1VtecSi
Aug 14, 2004 11:06 AM
WICKED2
Jan 21, 2002 12:43 AM
