motor swap....no start
Old Jul 29, 2004 | 08:19 PM
Acuraman918's Avatar
Default motor swap....no start
I have swaped a 90 crx hf mpfi motor into my 91 std dpfi civic hatch. She has fuel and spark, but just cranks over and over. My father cupped his hand over the opening to the intake manifold, and it started to actually almost start. I have no engine error codes. My wiring is mint, not sodered yet, becuase I was waiting to "finish" my wiring until I get it to run. I need some ideas on what is wrong with my baby, please help me. Also the hf motor has a mini fuel filter looking thingy at the left side of the fuel rail with a male end plug on it, what the hell is it, and could it be part of my problem?
Old Aug 2, 2004 | 06:42 PM
Default Re: motor swap....no start (Acuraman918)
TTT
Old Aug 2, 2004 | 07:14 PM
mr. carpenter's Avatar
spray a starting fluid into the tb. if it starts then it's not getting fuel or it was just flooded. wd40 works.
Old Aug 2, 2004 | 07:35 PM
mrchaos's Avatar
edit...wrong post
Old Aug 2, 2004 | 07:48 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acuraman918 &raquo;</TD></TR><TR><TD CLASS="quote">Also the hf motor has a mini fuel filter looking thingy at the left side of the fuel rail with a male end plug on it, what the hell is it, and could it be part of my problem?</TD></TR></TABLE>
no, it is just a cover on the connection - what engine wiring harness are you using? are plug wires in correct order? do you get Check Engine Light? codes?
Old Aug 2, 2004 | 07:53 PM
green91's Avatar
unless you are using the DX DPFI intake manifold, you need to wire it for mpfi for it to run.. also need a mpfi computer
Old Aug 2, 2004 | 08:19 PM
Default Re: motor swap....no start (jlicrx)
I'm using my stock std harness. I am thinking I might have my injectors plugged in the wrong order. I get no error codes
Old Aug 3, 2004 | 01:09 PM
TTT please help guys!
Old Aug 4, 2004 | 04:39 PM
Bump!!
Old Aug 4, 2004 | 05:07 PM
daidilus's Avatar
yo using the STD intake manifold or the HF?
Old Aug 4, 2004 | 05:29 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acuraman918 &raquo;</TD></TR><TR><TD CLASS="quote"> Also the hf motor has a mini fuel filter looking thingy at the left side of the fuel rail with a male end plug on it, what the hell is it, and could it be part of my problem?</TD></TR></TABLE>
Does it look something like this? if this is what ou are talking about, it is just your fuel pulsation dampener. But I dont think it would be the cause of your problem.
Old Aug 4, 2004 | 06:47 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acuraman918 &raquo;</TD></TR><TR><TD CLASS="quote">Bump!!</TD></TR></TABLE>
check your IM
Old Aug 4, 2004 | 08:23 PM
Default Re: motor swap....no start (BlueShadow)
it's way bigger with an electronic plug on it...I'll try and get some pics tomorrow
I am using the hf manifold. thanks for hanging in there guys
Old Aug 4, 2004 | 08:39 PM
oh..I also have everything... the hf motor was complete that I put it. I was told that it ran when it came out. so the dizzy is the right one and the manifold is good. I bought a pm6 ecu and converted my stock std harness for the four injectors with the "twinky" box. I'm just not understanding why I can't get it to run. I am getting fuel into the rail, so it must be an injector problem or a wiring problem. I tried switching the white wires on the dizzy...didn't work. does anybody know anyone that is located neer Bangor, Maine that has done this before. I can buy beer or food or whatever it takes to get some assistance.
Old Aug 6, 2004 | 06:41 PM
I'm working on getting the pictures upload. I am not getting fuel. I have to figure out my vacume hoses, and figure out what that thing is on the left of my fuel rail.
Old Aug 6, 2004 | 06:55 PM
If you guys need anymore info please just ask....I need all the help I can get, as you can see
Old Aug 6, 2004 | 07:17 PM
iam94wcyy's Avatar
Default Re: motor swap....no start (iam94wcyy)
Old Aug 6, 2004 | 07:18 PM
iam94wcyy's Avatar
Old Aug 6, 2004 | 07:23 PM
iam94wcyy's Avatar
Old Aug 7, 2004 | 05:07 AM
That damn thing is the EGR vavle....how do I hook it up electrically, and does anyone have a good vacume diagram?
Old Aug 8, 2004 | 06:52 AM
iam94wcyy's Avatar
dilysi on customcivics says it can be bypassed
Old Aug 9, 2004 | 08:47 AM
iam94wcyy's Avatar
how do you bypass the egr vavle?
Old Aug 10, 2004 | 07:23 PM
TTT I'm figuring things out everyday. Does anyone know where I could buy a Control Box that includes the MAP sensor?
FineCRX
10
May 31, 2019 12:36 PM
WestTxSR20
Sep 9, 2010 05:12 AM
<(boogieman)>(666)
Jul 2, 2009 11:46 AM
TsujenDB1
May 12, 2006 06:04 AM
