How To Modify A6 Dist To Fit Z6 Head ? PLEASE!
Old Jul 29, 2004 | 08:02 PM
drnovascotia's Avatar
Default How To Modify A6 Dist To Fit Z6 Head ? PLEASE!
so I searched. I can't find any pics or write-ups about how to hack up the a6 dist to the z6 head. I dremeled the mount where the dist bolts to, but see that most people use washers. What for? What do I need to do ? I believe thise is retarding my timing so much it won't start. . help!
THANKS!
Dr.
Old Jul 29, 2004 | 09:26 PM
berettagtz117's Avatar
Default Re: How To Modify A6 Dist To Fit Z6 Head ? PLEASE! (drnovascotia)
Drill the top whole on the upside of dizzy to make it bigger and put a bolt in there and use two big washers one on each side of dizzy to tighten the bolts against the housing.( The side bolts do not go in the holes just in the threads the washer is what pushes the dizzy against the head.
Old Jul 30, 2004 | 04:10 PM
Default Re: How To Modify A6 Dist To Fit Z6 Head ? PLEASE! (berettagtz117)
the dizzy mounts up to the head just fine. . I dremeled it a bit and without a washer it lines up perfect, am I doing something wrong? can you elaborate or give me a pic ?
Dr.
Old Jul 30, 2004 | 04:24 PM
Sikocivic's Avatar
If it mounts up just fine then why won't your car start
The reason you have to grind out the holes and use some washers is so you can move the dizzy around when you are setting the timing.
Old Jul 30, 2004 | 04:33 PM
Sick79's Avatar
what i did was use a small pair of vice grips to hold the distributor on to the head.
than start the car and let it warm up to full operating temp. so i could adjust the timing. then i hooked up a timing light, and moved the distributor until the timing was at stock specs.
i then noted how much material i need to remove from the distributor so i could bolt the distributor on. i dremaled and hacksawed the excess material until i was able to get the bolts in. than you have to use 1 or 2 big washers on each bolt to hold the distributor in place.
i had to cut a small piece off of the top bolts washer so it would fit, because the washer i used was to big. i also bought new bolts so i would have enough thread since i was planning on using a few washers.
if you need pics, give me an email adress and ill send you some close up pics since i just had to mod my distributor 3 days ago. good luck.
Old Jul 31, 2004 | 01:23 PM
Default Re: How To Modify A6 Dist To Fit Z6 Head ? PLEASE! (Sick79)
drnovascotia@comcast.net is my email
some help would be greatly appreciated!
THANKS!
Dr.
Old Aug 2, 2004 | 06:58 PM
Tried it like that. . still no go!
Anyone else have any idead ? Dist. worked before the swap no problem!
Dr.
Old Aug 2, 2004 | 07:08 PM
mr. carpenter's Avatar
i've got pictures in this thread. as well as another guys way he did it which is actually the best i've seen it done.
https://honda-tech.com/zerothread?id=913151
Old Aug 3, 2004 | 03:44 PM
Default Re: How To Modify A6 Dist To Fit Z6 Head ? PLEASE! (mr. carpenter)
I checked those pics and tried it, car still wouldn't start.
So if the ECU error is dist it has to be the ignition coil, dist or ecu?
Dr.
Old Aug 4, 2004 | 10:54 AM
come on, all you honda techs and nobody with some help! Save me before I end up selling it not working !
Dr.
Old Aug 4, 2004 | 11:22 AM
Alright, so I did this http://www.we-todd-did-racing....3D%3D
Checked the black/yellow wire for signal, and got just under 12 volts, so thats good.
the second half http://www.we-todd-did-racing....3D%3D
says to use the test harness, which I don't have, so I can't do this . .
So how the heck am I to figure out what is causing my ECU error 15 ?
Any help at all?
Dr.
kr3wkid420
Sep 23, 2015 07:01 PM
marcsed6
Jan 3, 2010 12:34 PM
Manny86
May 22, 2007 10:17 AM
EK_vzla
Sep 21, 2004 02:15 PM
CRX Si
10
Aug 28, 2003 06:42 PM
