Boring out a B21
Old Jul 29, 2004 | 07:29 PM
AlienKrOZ's Avatar
Default Boring out a B21
whats the biggest that you can bore a b21 out to? 87mm? 89mm? i believe the stock is a 84mm?
Old Jul 29, 2004 | 07:52 PM
TrackWeapon's Avatar
Default Re: Boring out a B21 (AlienKrOZ)
depends if you plan to go turbo
anyway with an h22 it's recommended to not go over 89mm for boost and 90mm for na, that's whit a 87mm stock bore
so if taking the same rule of thumb, the MAX would be a 3mm over with 87mm, but that would be pretty hard, you may not keep it that long!!!
Old Jul 29, 2004 | 10:35 PM
AlienKrOZ's Avatar
Default Re: Boring out a B21 (TrackWeapon)
planning 2 boost it
Drifter6508
Nov 3, 2009 09:27 AM
Drifter6508
Appearance Build Threads
Nov 2, 2009 03:12 PM
90acc-lude
Mar 22, 2006 06:43 AM
Liquid R6
Aug 17, 2004 02:11 AM
