i found oil in my intake....help..
Old Nov 27, 2001 | 03:57 PM
SjCiViCHB's Avatar
Default i found oil in my intake....help..
is that normal or is that bad? while installing my new throttle body i found oil in my intake, is that a normal thing or a bad thing? how the hell did oil get in the first place? and if its bad how can i fix it?
Old Nov 27, 2001 | 04:25 PM
Gump's Avatar
Default Re: i found oil in my intake....help.. (SjCiViCHB)
from hitting vtec
Old Nov 27, 2001 | 04:51 PM
SjCiViCHB's Avatar
Default Re: i found oil in my intake....help.. (xlr8si)
really? wow, how does that happen when my vtec dont work currently, its been broken for about 3-4 months now.
Old Nov 27, 2001 | 04:54 PM
Gump's Avatar
a honda mechanic told me that it happens when you hit vtec, i check my intake a while back and it had it too but not alot
Old Nov 27, 2001 | 06:06 PM
SBR*EG4's Avatar
the hose coming off your valve cover is called positive crankcase ventilation and allows blow by gases(oil moisturized air etc...) to reenter the intake tract for emissions purposes; as with the hose from the oil cooler to the intake manifold.
Old Nov 27, 2001 | 06:43 PM
rainforest's Avatar
Default Re: i found oil in my intake....help.. (N4Y2C0E)
this can be alleveaited (big word) by a oil catch can. thats what they do they filter oil from your pcv to the intake so there is no hot oil reentering your motor.
Old Nov 27, 2001 | 09:47 PM
Crossett's Avatar
from hitting vtec
^--- that is just stupid
The guys talking about the PCV are right. And IMHO an oil catch can is a very good thing to have.
Old Nov 28, 2001 | 08:39 AM
Duck Sauce's Avatar
Default Re: i found oil in my intake....help.. (Crossett)
You can prevent that, by simply yanking off the crankcase hose and sticking on one of those mini-K&N crankcase breathers. And if you have an intake, stick another one on the tube with the protursion for the hose.
[Modified by www.s4-mtm.com, 5:40 PM 11/28/2001]
Old Nov 28, 2001 | 11:00 PM
SjCiViCHB's Avatar
Default Re: i found oil in my intake....help.. (www.s4-mtm.com)
but then wouldnt i just get oil on my engine by doing that?
Old Nov 28, 2001 | 11:06 PM
Lt. Dan's Avatar
If you do that little "filter" mod, you'll also be breaking the law.... that tube is there for a reason...
Dan
Old Nov 28, 2001 | 11:48 PM
Duck Sauce's Avatar
Default Re: i found oil in my intake....help.. (Lt. Dan)
Hey LT...most intakes aren't CARB legal anyways, so who gives a F. And no, you won't get oil in your engine by doing that. That's why I suggested it.
Old Nov 29, 2001 | 07:32 AM
Kalokohan's Avatar
New User
Default Re: i found oil in my intake....help.. (rainforest)
From what I heard, an oil catch can is only needed in turbo applications. It's normal for that oil to re-enter the tb and if you do a search, using one of those breather thingies is bad for your engine.
Old Dec 17, 2001 | 01:33 PM
B18CJDM's Avatar
That will not work all it will do is drip oil all over you intake manfold To do it properly you need a catch can.
Old Dec 17, 2001 | 02:21 PM
976's Avatar
976
New User
Default Re: i found oil in my intake....help.. (B18CJDM)
Are you sure it's oil, not a lot of carbon build up?
Oil vapor collects in t/b - make a open loop PCV system...
Old Dec 17, 2001 | 02:22 PM
976's Avatar
976
New User
Hmmm, now I want to buy two of those little breathers even more!
Old Dec 17, 2001 | 07:54 PM
Guitarzann's Avatar
Default Re: i found oil in my intake....help.. (B21A)
I have a hose running from the valve cover, down to the ground with a filter on the end
I'll get a catch can eventually.
Old Dec 18, 2001 | 06:08 AM
pregunta's Avatar
Default Re: i found oil in my intake....help.. (Guitarzann)
Kinda off subject but along the same lines. I have an oil catch can in my car but it is only attached the the hose comming off of the head cover should I run both lines (crankcase cover and PCV lines) to the oil catch can then run two lines back to to the intake manifold and to the short ram or leavt it the way it is.
Old Dec 18, 2001 | 06:22 AM
sackdz's Avatar
Default Re: i found oil in my intake....help.. (pregunta)
Here.
Old Dec 18, 2001 | 05:32 PM
SjCiViCHB's Avatar
Default Re: i found oil in my intake....help.. (sackdz)
wows...this was old, and i didnt car too much for it, but now that ive seen that diagram fo yours sackdz, i think i should invest in the oil catch can now. Thanks for the diagram. how much do those things usually go for anyways?
Old Dec 18, 2001 | 06:30 PM
brinks's Avatar
The flow of air on a b series motor is from the intake into the valve cover, not vice versa. By outting on a breather you are doing NOTHING. Dont believe me? check the flow diagram in your shop manual.
Old Dec 19, 2001 | 06:20 AM
pregunta's Avatar
Default Re: i found oil in my intake....help.. (brinks)
Ok repeat of question but in different mannor. I have a PCV valve and the breather from the head cover. I know what it says in the diagram but which should I be concerned with the PCV valve or the breather when it comes onto the oil catch can.
Old Dec 19, 2001 | 07:11 AM
Perfectionist's Avatar
Forget about the catch can for now. Make sure your PCV valve is working and the hose from it to the intake manifold isn't clogged. The hose at your intake (before the throttle plate) is there to allow fresh air into the crank case by way of the valve cover. It normally shouldn't back flow oil and vapors, but if you have excessive blow by or a clogged PCV valve I suppose it would.
Old Dec 19, 2001 | 07:20 AM
pregunta's Avatar
Default Re: i found oil in my intake....help.. (Perfectionist)
So if I am reading your reply correctly. And everything is working correctly. The all I have to worry about with the oil catch can is the PCV valve. Right?
Old Dec 22, 2001 | 12:11 PM
Default Re: i found oil in my intake....help.. (1fastBITCH)
"""!!!!!!!clean air sucked in only,...no recurculaiting crap!!"""
If everyone thought like you, soon there would be no clean air to suck in.
Old Dec 22, 2001 | 10:18 PM
pregunta's Avatar
I care about emissions My car is a daily driver. Want it to pass inspection.
jrdnwheeler
Sep 3, 2008 08:48 AM
JDMcb7
Apr 24, 2005 10:31 PM
matix
Sep 19, 2004 10:17 PM
GUNNER666
Jul 12, 2004 08:10 AM
im a monster hehe
27
Aug 14, 2003 10:04 PM
