Loud header?
Old Jul 29, 2004 | 03:50 PM
aandDavidsaid's Avatar
Default Loud header?
i just install some an-r header on my car andit is really loud is there something that i can do to lessen the noise
Old Jul 29, 2004 | 03:54 PM
antiJDM's Avatar
put the stock exhaust manifold back on?
get a muffler?
Old Jul 29, 2004 | 04:19 PM
Default Re: Loud header? (jdmrac3r)
getting a muffler will help?
Old Jul 29, 2004 | 04:21 PM
SiYouLater's Avatar
put on ur stock header.
Old Jul 29, 2004 | 04:45 PM
dantastic's Avatar
are u sure u dont have any leaks? i've installed all sorts of headers before and i've never heard a car get significantly louder from just the header
Old Jul 29, 2004 | 04:58 PM
chronodyne28's Avatar
Default Re: (dantastic)
When I installed my header I can now hear ticking. I've looked for a leak and no such find.
Old Jul 29, 2004 | 05:06 PM
thrty8street's Avatar
Default Re: (chronodyne28)
maybe you forgot to install the donut gasket?
thats what happened to me the first time and it sounded horrible, then i put the gasket on and it was perfect.
make sure the bolts are on tight so you have no leaks. turn on the car and place your hand around where the header connects to the cat to see if your leaking air.
Old Jul 29, 2004 | 05:22 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmrac3r &raquo;</TD></TR><TR><TD CLASS="quote">i just install some an-r header on my car andit is really loud is there something that i can do to lessen the noise</TD></TR></TABLE>
If you went from a stock header to the AN-R, your exhaust note may have increased, but it shouldn't be a huge different. As the others stated, check for leaks, as a even a small leak can get extremely loud, and annoying.
Old Jul 29, 2004 | 07:08 PM
Default Re: Loud header? (rodrez)
so how or where do i check for the leak. can i go to a shop to get it fixed.
Old Jul 29, 2004 | 07:39 PM
bump
Old Jul 29, 2004 | 08:55 PM
Old Jul 29, 2004 | 09:40 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmrac3r &raquo;</TD></TR><TR><TD CLASS="quote">so how or where do i check for the leak. can i go to a shop to get it fixed.</TD></TR></TABLE>
As explained above, turn the car on, go underneath and feel around (don't touch anything) for any air pushing out. Most likely it's leaking where the header meets the straight pipe/cat.
Old Jul 29, 2004 | 10:12 PM
InsertCleverSN's Avatar
is the loud noise coming from the tial pipe or the front? if its the front then u have an exhaust leak, could be that u just need to tighten the bolts, or put in a gasket
Old Jul 29, 2004 | 10:31 PM
thanks rodrez i found where it was leaking air. it was leaking where the header was bolted to the head. do u think i need a new gasket. thanks
Old Jul 29, 2004 | 10:33 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmrac3r &raquo;</TD></TR><TR><TD CLASS="quote">thanks rodrez i found where it was leaking air. it was leaking where the header was bolted to the head. do u think i need a new gasket. thanks</TD></TR></TABLE>
Yeah, you might. Did you torque it to spec? Did you reuse the same gasket that was on there?
Old Jul 29, 2004 | 10:40 PM
torque it to spec? yea i used the same gasket
Old Jul 29, 2004 | 10:42 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmrac3r &raquo;</TD></TR><TR><TD CLASS="quote">torque it to spec? yea i used the same gasket</TD></TR></TABLE>
Sounds like you either didn't tighten it enough (be careful, if you have access to a torque wrench and a manual, grab it), or your gasket is bad. Might want to swap it out.
It could be the flange itself on the header, but I doubt it, as I've only heard very good things about the AN-R quality.
Old Jul 29, 2004 | 10:44 PM
what kindof gasket should i get a stock one or aftermarket.
Old Jul 29, 2004 | 10:47 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmrac3r &raquo;</TD></TR><TR><TD CLASS="quote">what kindof gasket should i get a stock one or aftermarket. </TD></TR></TABLE>
Stock will do the trick
Old Jul 29, 2004 | 10:52 PM
where can i get it at a honda dealership
Old Jul 29, 2004 | 10:53 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmrac3r &raquo;</TD></TR><TR><TD CLASS="quote">where can i get it at a honda dealership</TD></TR></TABLE>
Yes sir.
Old Jul 30, 2004 | 01:34 AM
phobi9's Avatar
make sure you torque it right this time; you can't just twist away with a rachet until it feels tight. You have to get a torque wrench (you can borrow one from autozone) and make sure each bolt is at a certain lb-ft (check helms or w/e).
-gl-
Old Jul 30, 2004 | 10:01 AM
Default Re: Loud header? (phobi9)
so i can borrowone from autozone and how much lb-ft is it 23
Old Jul 30, 2004 | 12:28 PM
is there a thicker kind of gasket i can find
Old Jul 30, 2004 | 12:32 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmrac3r &raquo;</TD></TR><TR><TD CLASS="quote">is there a thicker kind of gasket i can find</TD></TR></TABLE>
You won't need a thicker gasket, the stock one will work perfect.
True, you always want to torque everything to spec, with a quality torque wrench, although I never have for a header. I've probably used 7-8 different ones on my motors, and just tighten starting from the middle, working my way outward. But if you have acess to the correct tools, use them.
baked_beanz
Apr 21, 2005 12:29 PM
Red_Si
20
Dec 16, 2004 08:13 AM
builtprelude
Jun 10, 2004 10:28 AM
xmilanoredsix
Feb 19, 2004 06:44 PM
geminis2k
Apr 15, 2003 05:59 PM
