blowin fuses....help
Old Jul 29, 2004 | 02:13 PM
Half_BlkandAsn's Avatar
Default blowin fuses....help
i keep blowing my cluster fuse and a few others....i just put some aftermarket hyperwhite bulbs in my cluster but left one stock...could this be the cause to the blowing fuses???...it started once i changed the bulbs...my turn signal fuses did go out every time i used the signals but i stopped that by usin a 10a fuse to a 15 a fuse....bad idea????
Old Jul 29, 2004 | 03:10 PM
Default Re: blowin fuses....help (Half_BlkandAsn)
anyone????
Old Jul 29, 2004 | 11:30 PM
electrical's Avatar
by leaving one stock, that would NOT be the cause of the fuses blowing.
The fuses are probably blowing because the new bulbs pull more juice.
to fix this....install a bigger fuse. BUT MAKE SURE THE *ENTIRE CIRCUIT* CAN HANDLE THE ADDITIONAL CURRENT, if the circuit can't handle the extra power, then you can possibly burn up wires and traces. They'll just heat up and melt.
And traces are very thin. oh ya, traces are those "wires" on a circuit board.
Old Jul 30, 2004 | 06:29 PM
Default Re: blowin fuses....help (electrical)
thanx man...i just talked to my brother and he said the same thing...ill get on that and tell you what happened asap
agustintorre
Sep 14, 2012 06:55 PM
lilsicsoul
Mar 14, 2009 02:30 PM
timntam
Feb 3, 2006 11:10 AM
Civic92Turbo
Oct 14, 2004 08:13 AM
BoostedSi
Feb 23, 2003 08:59 PM
