pulled spark plug wire and nothing happens...why??
Old Jul 29, 2004 | 01:24 PM
hondaeg8's Avatar
Default pulled spark plug wire and nothing happens...why??
posting for a friend:
why the car was running, he pulled spark plug wire number 3 and nothing happened. same goes for spark plug wire number 2, when pulled off with the car running and nothing happened.
he took the # 1 spark plug wire off while the car was running and the car wanted to die out. samething for the number 4 spark plug wire.
why when number 2 and 3 spark plug wire was taken off while the car running, nothing would happend. the car still idled fine and didn't sound like it wanted to turn off?
also....the number 2 spark plug wire had gas on it....why is that?
Old Jul 29, 2004 | 05:35 PM
hondaeg8's Avatar
Default Re: pulled spark plug wire and nothing happens...why?? (hondaeg8)
Old Jul 29, 2004 | 09:36 PM
hondaeg8's Avatar
anyone have an idea?
Old Jul 29, 2004 | 09:38 PM
forced00si's Avatar
blown head gasket between cylenders maybe?
Old Jul 29, 2004 | 09:39 PM
MPower332TI's Avatar
Does the car have any mecahanical problems???? When you take the wire off the car wont always try to die. It should just slow idle speed a bit and click. LIke "click, click, click, click. } If the car runs fine i wouldnt worry about it.
Old Jul 29, 2004 | 09:42 PM
hondaeg8's Avatar
yeah...there's something wrong with the car.
the compression numbers are:
210 185 210 210
there is no signs of a blown head gasket though. thats what my friend was thinking too.
Old Jul 29, 2004 | 10:03 PM
Oh well you didnt mention that. He's ethier got busted ring lands, hole in a piston or some bent valves. Was he running nitrous??
Old Jul 29, 2004 | 10:04 PM
hondaeg8's Avatar
Default Re: pulled spark plug wire and nothing happens...why?? (MPower332TI)
no nitrous...just a i/h/e
i wasn't sure if the compression numbers would have anything to do with it.
i told him its doing that cause i think he has bent valves.
he did a leak down test and air came out through the exhaust and intake manifold, but not through the oil cap.
Old Jul 29, 2004 | 10:07 PM
B16Drag's Avatar
why dont u try take wire 2 or 3 off and try taking it around the block? Tell me if it runs right....
Old Jul 29, 2004 | 10:09 PM
hondaeg8's Avatar
what would that do?
he doesn't want to drive the car until he can figure out why the compression is low on the number 2 cyl.
Old Jul 29, 2004 | 10:30 PM
B16Drag's Avatar
Ive always thought a difference of 10-15% between cylinders was ok... <SHRUG> I dont think its a drastic drop in pressure...
can you clarify on exactly what he did.... Im still trying to understand exactly what he did. If he pulled the wires while the car was still on, and then pulled out the spark plug after wards? You do realize he is flooding the cylinder that has no sparks with fuel right?
Old Jul 29, 2004 | 10:37 PM
hondaeg8's Avatar
he had the car on and he was pulling the spark plug wire off one by one to see what the car would sound like.
when he pulled off the # 1 and 4 wire, the car sounded like it wanted to die out, like it normally would.
when he pulled off the #2 and 3 wire, the car didn't have a change in sound and it didn't seem like the car wanted to die out.
it stayed idling just fine like he never took off the spark plug wire.
vsmftw98
Aug 4, 2009 02:14 PM
spens 91 Ef
Feb 10, 2009 01:31 PM
hondaeg8
Jul 29, 2004 06:20 PM
slowd16z6
Mar 13, 2004 07:12 PM
