Right Side Wheel noise
Old Jul 29, 2004 | 12:40 PM
BlueRocket's Avatar
Default Right Side Wheel noise
So here is the deal. When I put the car in reverse, it makes a humming noise from the right side front wheel. After I put into 1st it sounds like something is scraping against metal. I hit the brakes and it stops. It doesn't do it all of the time, only every once and a while. I've had the car up and the wheel off and I can't see anything that is rubbing. Could it be bearings? Any Ideas?
Old Jul 29, 2004 | 09:17 PM
dsowers19's Avatar
Default Re: Right Side Wheel noise (BlueRocket)
have you checked the brakes and rotors yet?
Old Jul 29, 2004 | 09:27 PM
JRizEJ6's Avatar
Default Re: Right Side Wheel noise (dsowers19)
early brake wear warning. it happend to me. theres a lil piece of metal on your brake pads that start to scrape your rotos when your pads a runnin thin. change em
Dm914
Dec 11, 2015 02:12 PM
scuzzi
Nov 5, 2012 07:53 AM
buymesomedunks
Aug 10, 2012 10:09 AM
jumpin4abeat
Aug 12, 2011 06:36 AM
RolioPolio
Jun 29, 2002 01:38 AM
