wiring IAB. i need a 100% confirmation before i go and do this
Old Jul 29, 2004 | 12:26 PM
AzntaggeR's Avatar
TSPeed Factory
Default wiring IAB. i need a 100% confirmation before i go and do this
ok here's the setup.
94 del sol S (obd-1)
94 B18C1 motor (obd-1)
GSR engine harness (obd-1)
USDM P72 ECU(obd-1)
so is it as simple as just swapping pin A17 and A20 with eachother and i will have my IABs hooked up?
Old Jul 29, 2004 | 12:46 PM
poison's Avatar
Default Re: wiring IAB. i need a 100% confirmation before i go and do this (AzntaggeR)
No, you need to manually wire it to A17 and the other to positive source.
Old Jul 29, 2004 | 01:27 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: wiring IAB. i need a 100% confirmation before i go and do this (poison)
ok thanks. so can i wire it up to a constant power source such as a battery or does it have to be a 12v switch?
Old Jul 29, 2004 | 01:39 PM
AzntaggeR's Avatar
TSPeed Factory
ok i wired it up to a power source and now i'm throwing a CEL and it won't let me rev past 3k rpms.
Old Jul 29, 2004 | 02:00 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks. so can i wire it up to a constant power source such as a battery or does it have to be a 12v switch?</TD></TR></TABLE>
No, you need sensor voltage (any small guage yel/blk or blk/yel).
Whats your CEL?
Old Jul 29, 2004 | 02:03 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: wiring IAB. i need a 100% confirmation before i go and do this (turbogixxer)
ok i did it!! wired the pink/blue wire to A17 and the yellow/black wire to A25. thanks
jdmthug
Mar 11, 2007 11:04 PM
faSHOwidIT
11
Jun 20, 2006 03:09 PM
tianporn
Jan 29, 2006 02:44 AM
TurboBumblBee
30
Mar 5, 2003 10:26 AM
