Understeer/Oversteer????
Old Nov 27, 2001 | 02:07 PM
Phat Corolla's Avatar
New User
Default Understeer/Oversteer????
What is the definition of both these terms? I have never been exactly sure. Quite a few people seem to think that these are important things to be aware of, so I'd like to know what I'm talking about also.
Old Nov 27, 2001 | 02:13 PM
b18bvudoo's Avatar
New User
Default Re: Understeer/Oversteer???? (Phat GS-R)
oversteer is when your tail flings around on a turn and you're facing oncoming traffic. understeer is when your car doesnt want to turn as much as you'd like and you fly into the ditch.
Old Nov 27, 2001 | 02:14 PM
New User
Default Re: Understeer/Oversteer???? (vudoo666)
Okay, got it. Thanks. It's pretty much what it sounds like then.
Old Nov 27, 2001 | 02:16 PM
Mario's Avatar
Play GT3 and you'll know all about what those terms signify.
Old Nov 27, 2001 | 02:18 PM
New User
Default Re: Understeer/Oversteer???? (Supersonic DC2)
I don't have any gaming consoles...not to mention time to play with them. If I ever come across an opportunity to play it, I'll pay attention to those aspects.
Old Nov 27, 2001 | 02:22 PM
zeoth's Avatar
Graphically you can also look at it this way...
When you enter a turn and you OVERSTEER, that means you "turned too much" and the front of the car is headed towards the inside of the turn.
Same idea if you UNDERSTEER meaning you "didn't turn enough" and the front of the car goes towards the outside of the turn.
Like they said above, this is caused by wheels losing tracktion.
Let's say you enter a turn and gun the accellerator. For front wheel drive cars, the front wheels will slide causing the front of the car to seemingly go straight thus called UNDERSTEER. Same idea for rear wheel drive where the rear tires keeps going straight instead of turning thus making the front of the car seem like it's heading towards the inside of the turn.
Old Nov 27, 2001 | 09:31 PM
speedymon's Avatar
Default Re: Understeer/Oversteer???? (zeoth)
My GSR just leans too damn much. I feel like I'm in a caddy. I need a sway bar.
Old Nov 27, 2001 | 09:49 PM
nugget8000's Avatar
New User
Default Re: Understeer/Oversteer???? (speedymon)
Understeer: when the front tires loose traction first when in a turn.
Oversteer: when the rear tires loose traction first when in a turn.
Old Nov 27, 2001 | 11:05 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Understeer/Oversteer???? (nugget8000)
Oversteer scares the passengers.....
Understeer scares the driver!!!!!
Old Nov 27, 2001 | 11:58 PM
Anthony K's Avatar
New User
Try some stiffer springs and good shocks too.
Old Nov 28, 2001 | 01:33 AM
Rhetoric's Avatar
I got most of mine from GT2
Old Nov 28, 2001 | 08:06 AM
96IntegraLS4DR's Avatar
Understeer is when you try to turn at the corner and the car wants to go straight.
Oversteer is the opposite of understeer, front of the car will want to go farther inside the turn.
Old Nov 28, 2001 | 08:07 AM
MrBite's Avatar
Old Nov 28, 2001 | 05:17 PM
98SILVERGSR's Avatar
From: I want a 3some with Chasey Lane and Jenna Jameson, Canada
Default Re: Understeer/Oversteer???? (Mista Bone)
LOL...good analogy
Old Nov 28, 2001 | 05:22 PM
gsr camel's Avatar
extreme mental thoughts of both......
Over steer
turn the wheel fast and at the same time pull the E-brake handel
Understeer
rev it to 5K dump the clutch and when u start going turn the wheel to the left.
PS: dont attempt unless you are a ricer and if you are then go ahead! just simplifing it 4 everyone
Twanks
BoM's Avatar
BoM
Default Re: Understeer/Oversteer???? (98SILVERGSR)
and drifting scares everyone! even spectators....well us that is, not them crazy japanese tuners....
and their steering with all four wheels
-bom
who has been addicted to initial D
Old Nov 29, 2001 | 03:33 AM
Mista Bone's Avatar
D Tranny Guru
It was in someones sig line on CRX Forum.
Personally, I'm not used to the rear even thinking about steping out!
SOHC can't power out if rear snaps around.
Old Nov 29, 2001 | 04:28 AM
gsr stuie's Avatar
understeer: pushing towards the outside of the corner.
Oversteer: basically the tail(back of the car) wants to be in the lead.
EngineNoO9
Honda Motorcycles
40
Sep 9, 2006 11:35 AM
HondaHemi
Nov 10, 2005 01:50 PM
