Best brand of gas for the EM1 engine?
Old Jul 29, 2004 | 11:23 AM
pandacivic's Avatar
Default Best brand of gas for the EM1 engine?
I was using Chevron w/ Techron supreme octane 91 but changed to Unocal 76 w/ pro power octane 91. which is better for the '00 Si?
Old Jul 29, 2004 | 11:24 AM
Deemeetree's Avatar
Electrician
Any decent name 91/92/93 octane will do?
Modified by Dimi at 1:05 PM 7/29/2004
Old Jul 29, 2004 | 12:03 PM
JDM PRO's Avatar
Default Re: Best brand of gas for the EM1 engine? (pandacivic)
WAWA GAZ OR SHEETZ
j/p i use sunoco 94
Old Jul 29, 2004 | 12:05 PM
SiYouLater's Avatar
the Si's use higher octane, I think 93 octane.
Old Jul 29, 2004 | 12:06 PM
DemostheneZ's Avatar
Default Re: Best brand of gas for the EM1 engine? (99FBPSi)
interesting, i just assumed highest octane was the best..... what about d16z6
Old Jul 29, 2004 | 12:08 PM
SiYouLater's Avatar
Default Re: Best brand of gas for the EM1 engine? (DemostheneZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DemostheneZ &raquo;</TD></TR><TR><TD CLASS="quote">interesting, i just assumed highest octane was the best..... what about d16z6</TD></TR></TABLE>
i guess the d-series uses lower octane, im not sure.
Old Jul 29, 2004 | 12:14 PM
meccA's eg6's Avatar
its been proven that if your car is made for lower octane, puttin higher octane doesn't do anything and just wastes you money....
back to topic...i use 76 or ultramar
Old Jul 29, 2004 | 12:17 PM
eL's Avatar
eL
What does it say in the EM1's owners manual?
I have a b16a2 and I've only been using 89, oh well.
Old Jul 29, 2004 | 12:22 PM
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">What does it say in the EM1's owners manual?
I have a b16a2 and I've only been using 89, oh well.</TD></TR></TABLE>
i thikn all vtec motors need preminum, right?!?! except sohc vtec not sure on that one but i dont think it does
Old Jul 29, 2004 | 12:37 PM
Deemeetree's Avatar
Electrician
I doubt all VTEC motors need premium. If your compression is stock on a SOHC VTEC motor such as D16Z6, D16Y8, D15B and the VTEC-E models, you can and is recommended you use 87 octane. The higher compression motors such as DOHC VTEC motors are the ones that need 91+ octane. I use 89 octane on my stock D15B7 due to timing issues I haven't resolved yet. I ping with 87 octane. Need to get it done quick, tired of the pricier gas. Then again, filling up with 87 or 92 you're only going to put another 2 dollars more, why not?
Old Jul 29, 2004 | 12:45 PM
eL's Avatar
eL
I guess I should up my octane eh? lol.
Old Jul 29, 2004 | 01:03 PM
SiShane's Avatar
Default Re: (eL)
For Em1s it specifically say run premium gas. doesnt specify octane rating. I use BP 93 octane and the car runs like a champ. Occasionally ive run Pro-blend octane boost for races and there is a difference. I ran my best time at the local 8th mi. (9.75 @ 74) with it. Compared to the 9.9-10's I normally run. And there is significant pull on highway. Slowly pulled on a G35 and beat him from a 60 mph downshift.
Old Jul 29, 2004 | 01:16 PM
Default Re: (CRexer101)
unless your modified more then bolt ons i cant belive you can pull on a g35...they run 14's you dont
Old Jul 29, 2004 | 01:26 PM
SiShane's Avatar
Default Re: (meccA's eg6)
Mods: AEM V2, SA hyper grounds, Nology wires, denso iridiums, Ractive muffler. Im telling you there is some power to be made from that octane boost. But you dont have to believe me if you dont want I had witness's. He pulled ahead at first. I was in 3rd. towards 6500 I matched same speed and slowly started pulling then 4th we were side by side screaming. 5th gear I started slowly pass him. My window was at his front fender and he gave up. there were to other hondas (94 GSR & LS EG) I was the only car that hung and pulled on him.
square_1
19
Dec 30, 2007 06:50 PM
sohc dude
Dec 23, 2005 08:10 AM
motocross 04
Oct 19, 2004 06:02 PM
helen
Oct 27, 2002 01:19 AM
Yellow Dragon
Jan 30, 2002 05:03 PM
