Just got a 96 coupe.. what to do?
Old Jul 29, 2004 | 10:04 AM
mr2's Avatar
mr2
Default Just got a 96 coupe.. what to do?
well I just got a 96 coupe... it has around 50k miles on the motor..
what do you guys usually recommend done?
right now i am planning to.....
replace the front axle (goingout)
oil change
bled the brakes and change the pads if need be.
what else?
Old Jul 29, 2004 | 10:08 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Just got a 96 coupe.. what to do? (mr2)
Have you done a spark plug change yet? Check your plug wires and inspect the cap/rotor inside the distributor. Other than that, just check the rest of your fluids, and you'll be all set. (oil, coolant, PS, tranny, and umm.....wiper fluid)
EDIT: Are you talking just maintanence? Or modifications?
Modified by shamoo at 3:06 PM 7/29/2004
Old Jul 29, 2004 | 10:34 AM
97Civic-R's Avatar
Default Re: Just got a 96 coupe.. what to do? (shamoo)
B18 swap
Old Jul 29, 2004 | 10:41 AM
skunk2eg's Avatar
k20 swap
Old Jul 29, 2004 | 11:19 AM
Deemeetree's Avatar
Electrician
Pretty much top off all fluids with some good stuff.
Get GM Synchromesh Friction Modified for your tranny. $20 for 2 bottles from your local GM dealer.
Flush cooling system and check how your thermostat is operating.
Flush motor oil and get a new filter. Maybe upgrade to Synthetic.
Check all bushings.
Get new OEM plugs and OEM wires. Clean out distributor.
Change out fuel filter for a new OEM fuel filter.
Change airbox filter to a K&N drop-in.
Get all OEM parts from: http://www.slhondaparts.com or http://www.hondaautomotiveparts.com and you'll be set.
Old Jul 29, 2004 | 11:20 AM
crx_88_si's Avatar
Default Re: (Dimi)
i agree, tune up and top off
Old Jul 29, 2004 | 11:42 AM
JDM PRO's Avatar
do nothing b/c IT'S A HONDA . I didn't do any tune-up up until 100,000
Old Jul 29, 2004 | 11:49 AM
shamoo's Avatar
Default Re: Just got a 96 coupe.. what to do? (JDM PRO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM PRO &raquo;</TD></TR><TR><TD CLASS="quote">do nothing b/c IT'S A HONDA . I didn't do any tune-up up until 100,000</TD></TR></TABLE>
Old Jul 29, 2004 | 11:51 AM
Deemeetree's Avatar
Electrician
I feel sorry for you, but most of all, the neglect you give your Honda. Sell it to someone who will take care of it.
Modified by Dimi at 3:42 PM 7/29/2004
Old Jul 29, 2004 | 11:52 AM
Sijray21's Avatar
Default Re: Just got a 96 coupe.. what to do? (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">
I feel sorry for you, bust most of all, the neglect you give your Honda. Sell it to someone who will take care of it. </TD></TR></TABLE>
agreed....
Old Jul 29, 2004 | 01:30 PM
1995hondacivic's Avatar
i say get the usually first intake/headers/full exhaust/ upgrade brakes and get some coilovers. then maybe later on do a swap and turbo.
Old Jul 29, 2004 | 01:57 PM
projectej8's Avatar
Default Re: (1995hondacivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995hondacivic &raquo;</TD></TR><TR><TD CLASS="quote">i say get the usually first intake/headers/full exhaust/ upgrade brakes and get some coilovers. then maybe later on do a swap and turbo. </TD></TR></TABLE>
yes jackass spend $800+ on ihe only to just swap it out later on. I thought u cant have post like this? Rule #5 says no "what should i do next to my car next?" post. oh wait he can because he has around 65494 post.
Old Jul 29, 2004 | 05:00 PM
shamoo's Avatar
Default Re: (projectej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectej8 &raquo;</TD></TR><TR><TD CLASS="quote">yes jackass spend $800+ on ihe only to just swap it out later on. I thought u cant have post like this? Rule #5 says no "what should i do next to my car next?" post. oh wait he can because he has around 65494 post.</TD></TR></TABLE>
Good point on the waste of money on the I/H/E.
This post is a little different. I believe the poster is asking what type of maintenance should be done.
Old Jul 29, 2004 | 05:04 PM
DeviousCTR's Avatar
watever u do just make sure u do a swap first then work on cosmetics.. that wat i should have done.. wasted all my money and i gotta save up for a motor..
Nah-Roo-Toe
10
Mar 1, 2005 10:29 AM
mr2
Jul 29, 2004 03:36 PM
solid
Feb 9, 2004 01:00 PM
hb_racer
Mar 12, 2002 05:31 PM
