how do i check my tranny fluid???
Re: how do i check my tranny fluid??? (hb_racer)
Jack up the car so it is level, ie: on a lift or something, Not just from the front. Unbolt the the transmission fill plug. Its located on the back/passenger side of the tranny, about 4" from where the passenger side axle goes in. Remove the fill plug and stick your finger in. if there is oil to that point then it is full. If not add some till it pours out of the hole. DO NOT OVER FILL!!!! You should change you transmission oil every 15k miles or so.
-Alex
crispi_gts@yahoo.com
AIM: CrispiKreme
[Modified by 2kTypeRHatch, 11:28 AM 3/12/2002]
-Alex
AIM: CrispiKreme
pelotudo
07-21-2002 02:33 AM
