greddy profect b good?
It's just simple. Non of that "Fuzzy [thinking] Logic" crap. It has two boost settings: high and low. I wished it had different boost settings for different gears.. but it is a really nice unit. Hey, where can you find one for $200-$250?
What makes the B special? I mean what can it do that the A or any other boost controller do?
Fuzzy Logic have these wierd self learning procedures. PRofec B's are great boost controllers for the money and very easy to use! All you have to do is crank up the dial to turn up the boost. There are only 2 settings; Low & High. They also have a nice Sharpness feature which allows you to fine tune how fast you get to the desired boost level!
just install the controller and have difficult to set it profect b
my stock boost is 8 psi when my contoller is on its like 14 psi and over at low boost min or whatever setting ??? what the ****, i tried everything but cant have my stock setting 8 psi
plz help
plz help
you can also purchase a remote switch to switch from low boost to high boost. low boost on first gear
[Modified by LsTurbo91, 4:08 PM 11/27/2001]
The only problem I have run into is the amount of boost you can run on the PRofec B. It is *Supposedly* only able to boost 1.5x whatever your wastegate is set at! My deltagate had a 7-9 psi spring in it which was limiting me to about 16-17 psi. I swapped out the spring to the 13 psi spring and I have had no problems boosting to 19-20 psi!
So it would still work good for the low boost applications, I really am seriously wanting one of these now. I looked on ebay and the average "buy now" price is around $325, that a decent price?
Profec has a pretty large following and a very reliable track record, I'd say it's an excellent choice for $200-250.
That's really good.
For a good price on profec B's email this guy adam@aieonline.com I got mine from Adam for $293 + shipping of course so this is the best deal you are going to find it new for unless you buy a used one or something......
Just let him know that RADIADI@aol.com sent you and he will huck you right up!!!!
Later Fouks.....
AdvanceSpeedShop.com
Nov 14, 2008 11:12 AM
