Axxis Metal Master brake pad question...
Old Jul 29, 2004 | 08:16 AM
anekin007's Avatar
Default Axxis Metal Master brake pad question...
yesturday i received my axxis metal master pads that i won off ebay and got it for $12 shipped. i was wondering does it suppose to come with that metal peice that goes behind the pads? my first pad change i went cheap and bought some stuff from autozone and it had a peice to put on the back of the pads. check the picture..is there suppose to have the peice for the back of the pad? or it just straight install?
Old Jul 30, 2004 | 12:09 AM
StopChek's Avatar
Default Re: Axxis Metal Master brake pad question... (anekin007)
Each tire there are supposed to be two pieces sticking together. I know a place that sell pbr/axxis pads with a gud deal 714 608 0818
Old Jul 30, 2004 | 12:21 AM
crashN2u's Avatar
Are you talking about the shim? You can get replacement shims at autozone.
Old Jul 30, 2004 | 12:51 AM
K I T T's Avatar
Default Re: Axxis Metal Master brake pad question... (crashN2u)
Does it matter if the shims were ommitted?
I forgot to put on mine and got too lazy to install it.
Old Jul 30, 2004 | 06:05 AM
egizzle8
Guest
Posts: n/a
Default Re: Axxis Metal Master brake pad question... (Dexter's Lab)
Damn 12 shipped! I thought I got a deal for 20 shipped on mine. Haven't put them in yet but hopefully it should be better than whats in there now. Are these quite abit better and noticeable right away?
Old Jul 30, 2004 | 09:18 AM
anekin007's Avatar
Default Re: Axxis Metal Master brake pad question... (egizzle6)
i dont know if its called a shim..i did some search..some site called it a silencer plate..its that thin metal that goes on the back of the pad. is it suppse to come with one or did i get screwed? if i am missing it..is it even possible to get those parts? can i install it without the plate?
the thin plate on the back of the pad is the one im talking is the one i circle.
Old Jul 30, 2004 | 09:27 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
just install it. works fine.
Old Jul 30, 2004 | 09:32 AM
crashN2u's Avatar
I've bought brake pads that came with and without the shims. I just kept reusing my old ones. Now they are too rusted to be used again. I forgot what they are for. Just reuse your old one or get a replacement from honda or autozone.
Old Jul 30, 2004 | 09:51 AM
deeksmooth's Avatar
i installed my axxis ultimates w/out them... i don't know how that plate could silence a squeal, but the functionality of my brakes is grade A w/ brembo blanks on the 5 lug setup.
next brake change i'll put some on...
Old Aug 3, 2004 | 05:06 PM
StopChek's Avatar
Default Re: Axxis Metal Master brake pad question... (citrEK)
Performace pads dun need shims.
CDelgado220
Oct 4, 2011 08:09 AM
THMotorsports
Jan 11, 2006 02:23 PM
TurboTeG4
Dec 12, 2004 02:20 PM
tylerdurden
Jan 8, 2003 12:46 PM
Flux
Jul 19, 2002 05:36 PM
