Upper control arm ball joint replacement
Old Jul 29, 2004 | 08:16 AM
DaChoZn1's Avatar
Default Upper control arm ball joint replacement
I have a 96 Accord that needs a new upper control arm ball joint. Can I just replace the ball joint or do I have to replace the whole control arm w/ball joint assembly? I called a local Honda dealer and was told that the ball joints are not sold separately. I'd have to buy a new control arm. Is this true? It doesn't sound right. I'd appreciate any pertenant info you guys could provide. Thanks in advance.
Old Jul 29, 2004 | 01:05 PM
DaChoZn1's Avatar
Default Re: Upper control arm ball joint replacement (DaChoZn1)
I guess no one knows?
Old Jul 29, 2004 | 01:16 PM
JimBlake's Avatar
Well, I've always heard the same thing - you have to buy the upper control arms. I guess maybe I was hoping someone knew about a new way to get just the ball joints?
Old Jul 29, 2004 | 03:32 PM
georgelb's Avatar
Default Re: Upper control arm ball joint replacement (JimBlake)
try here
http://www.hondaautomotivepart...cgry5=
If they do not show it, you probably cannot buy the ball joint seperately.
Old Jul 29, 2004 | 05:19 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
your 2 options are:
either buy new arms from the dealer
or, buy a camber kit that will replace the upper balljoints or the whole assembly if you're planning on dropping your car in the future.
Old Jul 30, 2004 | 02:23 PM
dwolsten's Avatar
Call Autozone and see if they sell them. When I replaced my lower balljoint, they had an entry on the screen for an upper one.
LongJon
Jul 9, 2011 11:09 PM
XstouterX
Jan 9, 2006 10:31 PM
Echelon
14
Nov 30, 2005 11:06 AM
DaChoZn1
Sep 18, 2005 03:34 PM
SLOW4drINTEG
Nov 24, 2003 08:25 PM
