Drivetrain noise
Old Jul 29, 2004 | 07:04 AM
Elvis1977's Avatar
Default Drivetrain noise
Is it normal to hear a slight clunking noise when letting off the accelerator at very slow speeds? I have a 98 accord with 124k miles and 4-cyl. motor. At a standstill, if I accelerated quickly i cannot feel or hear nothing. But, if at a standstill when I accelerate VERY slowly SOMETIMES I hear and feel a slight clunk. Also, when coming to a stop i hear a slight clunk. Is this normal? I took the car to a HONDA dealership and had a foreman ride in the car with me to diagnose the possible problem. He says I have "drivetrain slack" and is normal with miles and age. IS THIS TRUE? Transmission shifts perfectly and fluid changed every 30k with genuine honda transmission fluid. All responses appreciated.
Old Jul 29, 2004 | 11:11 AM
Turbowa's Avatar
Default Re: Drivetrain noise (Elvis1977)
Yes, this is normal. With alot of milage on the car you clutch packs and valve bodys will wear. This will cause the car to shift slightly different then it did with less miles. Even with the fluid changed regularly there is still going to be wear on the internal parts. This will also be more pronounced when the tranny is cold.
Old Jul 29, 2004 | 11:14 AM
Legendaryyaj's Avatar
Default Re: Drivetrain noise (Turbowa)
OT but...hey turbowa!!!!! Wheres ur Accord at, it just fell off the planet of the earth after much hype made by you!?!?!??!?!?!?!?!?!??!
Old Jul 29, 2004 | 11:44 AM
Elvis1977's Avatar
Problem occurs when hot or cold. Does anybody else have this same situation I have described?
jvue
Oct 15, 2015 12:06 PM
artman
Jan 7, 2013 09:55 AM
gs_rbaby
Jul 19, 2009 01:14 AM
renloy
Jul 17, 2007 09:36 PM
