95' ACcord Rear speaker wiring???
The rear speakers have an unusual wiring connector with looks to be three wires going to the speaker. Which wires do I use to wire up aftermarket speakers? Which ones are ground and 12+?
Any websites with wiring diagrams?
If the replacement speakers are without a kit or technical assistance, the you may as well experiment.
If disastrous, which, IMO, is not that likely, little is really lost, knowledge is gained - I cannot see spending $125 for Honda replacement speakers, and they probably do not carry them anyway,
Also, with a multimeter, a man can at least determine which lead is the ground.
I'm not putting replacement Honda speakers in. I'm replacing the crappy stock honda speakers with aftermarket Kenwood speakers.
I remember installing my sisters stereo on her 98 civic. She had 4 wires going into one of the honda speaker adapters that connect to the plug on factory speakers. My '95 accord had that same BS.
Here is a wiring diagram for your Honda:
http://www.installdr.com/Harnesses/HA-Wiring.pdf
My sisters civic for some reason had 2 + and 2 - wires going into the plug adapter. I got some crimp connectors and crimped the +'s factory wiring on one side, did same for -'s and crimped aftermarket speaker wire to the other side. THen, just connected one + and - to the aftermarket speaker.
Z
Z
patrickvertigo
Audio / Security / Video
10
Feb 14, 2013 06:41 AM
reikso2h
Jun 25, 2009 10:04 AM
