1995 Honda Civic Stereo Wiring Issue
I am having issues with my front left speaker. I am running an Aiwa amplifier to the stock speakers, and recently the left front speaker cut out. Now the sound only comes out of that speaker intermittently. I seems like it must be a wiring issue, since sound still comes out of the speaker every once in a while. I checked the wiring to the receiver and it all seems to be hooked up correctly and securely. How would I be able to check the wiring between the amp and speaker? Would it be easiest to just run new wires? How would I do that?
Also, I live in the LA area. Does anyone know of a place that would be able to do this for me cheaply?
Thanks in advance for any help you might be able to offer.
Re: 1995 Honda Civic Stereo Wiring Issue
If you have a multimeter you could check the resistance between the speaker and the amp. Generally if something is intermittant like that it's a short in the wire.
I was baffled recently with an intermittent rear passenger and front passenger speaker problem on my 93 DX. I checked all the speakers' resistances (all sat); checked for grounds; checked for continuity; replaced the front set of speakers. I finally partly removed the radio from its frame and noticed that jiggling the radio consistently repeated the problem. I then narrowed it to jiggling a single wire going into the radio. Those dozen or so wires going into the radio are all of course multi-strand wire, so the one wire overall was passing the various continuity tests. It was just that a few of the one wire's strands were not well engaged in the connector, so if I held the wire one way, no speaker sound; another, and the speaker sound returned. I imagine the strands got pulled out from wear-and-tear over the years, like jerking the male and female connector ends apart or maybe cramming a bunch of aftermarket stereo wiring in the space behind the radio, putting stress on the wire ends. I replaced the end of the one wire going into the radio connector, and the problem is now fixed.
Properly releasing the wires from these connectors is one huge chore. I practiced at a junkyard until I had a decent idea of what I was doing. Get a precision screwdriver set.
patrickvertigo
Audio / Security / Video
04-11-2011 06:37 AM
