99 b18c1 idling at 1500 rpms. what causes this???
Old Jul 28, 2004 | 10:05 PM
SuicideSlide's Avatar
Default 99 b18c1 idling at 1500 rpms. what causes this???
Ive finally got all the check engine lights off my b18c1 swap. Im running a p28. After all the cels were finally taken care of I still have a high idle. After running hard sometimes it even stays at around 2k. Could my throttle cable need some adjustment. (it would be great if it were only that simple). I plugged in an old p75 just to see if maybe a different computer would idle it differenty. Nope... they both idled at 1500 rpms. So what causes this??? No CELS right now...
thanks
andrew
Old Jul 29, 2004 | 01:07 AM
hatchi's Avatar
Default Re: 99 b18c1 idling at 1500 rpms. what causes this??? (Tur*bLu)
check throttle cable slack. adjust tps, or tb idle screw
Old Jul 29, 2004 | 06:03 AM
Default Re: 99 b18c1 idling at 1500 rpms. what causes this??? (hatchi)
ok..I can do 2 of the 3.. how do I adjust the tps???
Old Jul 29, 2004 | 01:46 PM
TRF #001's Avatar
my friend had the same problem on his gsr wen he did a swap. is it the stock gsr manifold? cause on his it turned out he was suckin a piece of the intake gasket in where the secondary butterfly is located.
FATKID87
Honda CR-V & Element
Mar 26, 2014 07:52 AM
Hackura
Mar 12, 2009 03:17 PM
BJA86
Oct 5, 2008 01:54 PM
emooheo
Mar 23, 2007 02:34 PM
crx-si
10
Jan 30, 2003 07:26 AM
