which ecu chip is best(sohc plz)?
Old Jul 28, 2004 | 08:06 PM
eh2-hb's Avatar
Default which ecu chip is best(sohc plz)?
here are my mods....
*d16z6
aem cai, obx header, cuztom 2 1/4 pipin with revolution muffler,skunk2 came gear, skunk 2 im,b&m fpr settin at 42 psi,act xtss clutch, act street light fly wheel,skunk2 retainers valves springs and valves, and comp camshaft stg 1. i did a built on my head which includes resurfacing it to 4000 and 3 angle valve job...well anyways which ecu would work well with this setup i'm having, i need some pro and cons about ecu chips such as skunk2, kenji, or wutever for this motor that would work good...wut ecu chip are u using for your sohc?...thanks for any feedbacks
Old Jul 28, 2004 | 08:07 PM
eh2-hb's Avatar
Default Re: which ecu chip is best(sohc plz)? (eh2-hb)
also wut else parts do u think i need to get next besides doin anything to a stock block and fuel injectors. i plan on gettin fuel injectors and msd next but which parts next would you recommend...thanks oh yeah btw i'm goin nitrous,, already have zex kit but not setup yet
Old Jul 28, 2004 | 08:19 PM
dsadas89das78934's Avatar
i'm currently using a chip of my own programming
Old Jul 28, 2004 | 08:24 PM
BauleyCivic's Avatar
Risky Business
Default Re: (soccaian)
the best chip is VAFC, hondata, uberdata, AEM EMS
Old Jul 28, 2004 | 08:34 PM
eh2-hb's Avatar
Default Re: (BauleyCivic)
i just want something decent and easy instead of using hondata and other high tech programs that cost alot...but can you tell me the pros and cons when u refer to those chips? thanks
Old Jul 28, 2004 | 08:37 PM
honda9369's Avatar
Default Re: (eh2-hb)
skunk2
Old Jul 28, 2004 | 08:38 PM
Risky Business
No chip is perfect for your setup. Get something that allows you to adjust your A/F ratio, and go to the dyno. Its like having a custom chip perfectly set up for YOUR car.
eg6ajk's Avatar
some of the chips I offer, we have dynoed on SOHC. check the link below
http://www.hadamotorsport.com/...x.htm
thanks to Hada guys
Old Jul 28, 2004 | 09:30 PM
eh2-hb's Avatar
Default Re: which ecu chip is best(sohc plz)? (eg6ajk)
very nice...
Old Jul 28, 2004 | 09:33 PM
ABK's Avatar
ABK
yeah would recomend going with uberdata and get it tuned, since you got some extensive build up on your motor. no chip would be perfect because no one knows what your motor actually flows and how much fuel and ignition adjustment you will need to get the best power.
Old Jul 28, 2004 | 09:35 PM
mbdelsol's Avatar
Default Re: which ecu chip is best(sohc plz)? (ABK)
uberdata baby
Old Jul 28, 2004 | 09:40 PM
honda9369's Avatar
Default Re: which ecu chip is best(sohc plz)? (mbdelsol)
hrxc
Old Jul 28, 2004 | 09:52 PM
eh2-hb's Avatar
i heard alot of good things about uberdata...but i dont know any body in wa who makes them and can help me solder it to my p28 ecu....if only someone in wa can help...i'm willin to meet up and see wassup
h9civic3
Engine Management and Tuning
May 24, 2015 07:55 AM
feriotypeR
31
Feb 6, 2010 08:40 AM
2-logicl
Nov 21, 2005 06:31 PM
TheBlackCrx
Mar 12, 2004 10:45 AM
TurboTeG4
Feb 24, 2003 02:03 PM
