a few bore questions
Old Jul 28, 2004 | 07:21 PM
Sport_Injected's Avatar
Default a few bore questions
ok heres the story, i have a b16 block with some scratches in the cylinders (too deep for honing) so i want to bore them out and put in oversized civic type r pistons.
now, i have a few questions :
1. about how much do they charge to bore out your cylinders. i know each shop is different but can you give me an idea?
2. are shops able to do a good job so that they seal like stock pistons? like if i tell them to bore them to .25 (CTR oversized spec) will they seal like oem?
3. what piston rings do i use?
thank you guys. You are always very helpful.
Old Jul 29, 2004 | 09:44 PM
Default Re: a few bore questions (Sport_Injected)
Old Jul 29, 2004 | 10:26 PM
spaceman's Avatar
i wouldnt go to just any shop for work like that..i would look around for experts on the subject and make sure after they bore it you get correct size pistons then get correct size rings and make sure it will all work together.then install it all correctly...good luck
xjdmjunkiex
Feb 28, 2011 08:26 PM
user 98292739
Aug 15, 2009 07:26 PM
Yambor
Apr 29, 2005 10:55 PM
Sport_Injected
Jul 29, 2004 03:15 AM
granada_sun
Jul 31, 2003 12:09 AM
