GSR CIVIC SI OR 4th GEN. PRELUDE??????
Old Jul 28, 2004 | 07:00 PM
GSR civicSI prelude4THgen's Avatar
Default GSR CIVIC SI OR 4th GEN. PRELUDE??????
i have been deciding on what car i should get it is between the acura integra gsr 94-01 the civic si 99-00 and the 4th generation prelude all have vtec but different engine spex which most of u already know. the civic is the lightes weighing in at about 2600 pound with 111lbs of torque and 160 hp the gsr has 170hp wit about 128lbs/tq. and wieghs about 2700 lbs the prelude has about 190 hp but wieghs about 2900-3000lbs and about 156lbs/tq im not very sure wat to get they all run good times but im not only about the speed i just want an overall good car what should i do ??????????
Old Jul 28, 2004 | 08:53 PM
H22Psi's Avatar
Default Re: GSR CIVIC SI OR 4th GEN. PRELUDE?????? (GSR civicSI prelude4THgen)
Get a civic and your most likely to get jacked...get an Integra has the speed, and later on (depends on you) turbo it, GSR motors can handle boost with internal parts better then a prelude motor...prelude is a nice cruiser...has the h22a, which is a big motor...(good for all motor N/A) its a lot more time and work to boost that h22a motor...but if you have the time and money, then go for it. Hope that helps you out.
KUMAR
31
Jan 29, 2009 07:22 PM
Lude_Conduct
Jul 15, 2005 03:13 PM
John73900
Dec 1, 2004 03:24 PM
civicEXcon
Nov 2, 2004 07:15 PM
OxYi
Oct 22, 2004 03:43 PM
