how HARd...
hey guys, i was wondering how hard is it to remove and replace catalytic converter because my cat. is retarded... makes this RATTLING NOISE after i hit 2000 rpm... I want to just order a new one and put it on myself... b/c i no they wil charge me over 100 bux to remove & replace!
Fairly easy, give it a shot and remember to use jack stands. You'll have to get a small ring that goes between the cat and the exhaust. They only cost about 10 bucks from honda.
On the install difficulty level i'd give it a 2 out of ten.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hemp »</TD></TR><TR><TD CLASS="quote">Can be a real pain in the *** if the bolts are seized.</TD></TR></TABLE>
There is a good chance of this, but a breaker bar or a pipe to the wrench should do the trick.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BADEG6 »</TD></TR><TR><TD CLASS="quote">if it rattles you dont have to remove the cat just remove the heat shield y0!</TD></TR></TABLE>
Yeppp! Thats what I had to do this afternoon!
Just use a ratchet with a pipe over then end of it. And SLOWLY loosen it... like push on it let off a little push on it let off a little. You don't want to strip it or snap it
Yea its prolly the shield..mine rattled for a while cause it rusted out at the bolt points, but i fixed it by strappin it on with one of those screw on circular clamp things...sorry its late...
intgraCA
May 23, 2007 04:43 PM
SojournMystical
Sep 7, 2005 08:11 AM
slammedteg
Mar 15, 2004 04:48 PM
