Video diagnosis.....
Old Jul 28, 2004 | 06:53 PM
90crxsib16's Avatar
Default Video diagnosis.....
A video for you experts. Timing is at 16 degrees, no vacuum leaks, eacv fix is done, fitv fix is done, TPS is reset, no codes, new timing belt, new cap, new rotor, new plugs, new wires, new water pump, and no bubbles in the coolant system. You be the judge. Video is 6.47mb. Sorry 56k. Let me know if you have any thoughts or opinions. Thanks for your help.
Video HERE
Old Jul 28, 2004 | 07:18 PM
bossman032's Avatar
Default Re: Video diagnosis..... (90crxsib16)
try a different ECU.
did you try to mess with the idle screw give that a try
Old Jul 28, 2004 | 10:09 PM
DieMaster's Avatar
Needs to be About 20% Cooler
where did you get that exaust? thats bitchin
Old Jul 29, 2004 | 01:58 AM
90crxsib16's Avatar
Default Re: Video diagnosis..... (JC18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JC18 &raquo;</TD></TR><TR><TD CLASS="quote">where did you get that exaust? thats bitchin </TD></TR></TABLE>
Suprisingly enough, it consists of stock exhaust manifold, no resonator, 2.5"pipe, and a cheapie ebay "RS Type Super Turbo Muffler".
Old Jul 29, 2004 | 02:00 AM
90crxsib16's Avatar
Default Re: Video diagnosis..... (bossman032)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">try a different ECU.</TD></TR></TABLE>
I tried my D16a6(PM6?) ecu and the idle is the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">did you try to mess with the idle screw give that a try </TD></TR></TABLE> OK, thanks, I will.
Old Jul 29, 2004 | 02:45 AM
dr_latino999's Avatar
Wait, aren't you running a B16 in that car?
Old Jul 29, 2004 | 06:39 AM
crx_88_si's Avatar
you cleaned the IACV.. maybe replace it all together?
My d16a6 does the same thing. then after a hard run it's ok.. maybe o2?
$low_EF
20
Jan 1, 2007 01:19 AM
.Ry
Mar 17, 2005 02:23 PM
Civichatch27
Jan 27, 2005 02:55 PM
warrenbaity
Apr 16, 2004 11:43 AM
Denny
Nov 11, 2003 09:42 AM
