How to Bleed the ALB System
Old Jul 28, 2004 | 06:51 PM
samnt650's Avatar
Default How to Bleed the ALB System
I have 1988 Acura Legend w/ the dual brake reservoir Honda ALB system. This is the Honda version of the ABS and I believed it's the 1st generation ALB system. Can someone tell me how can I flush out all the old brake fluid and in w/ the new? The Honda ALB system is simply too strange for me. I am more familar w/ the Bosch ABS. THANKS
Old Jul 28, 2004 | 07:57 PM
murtnabila's Avatar
Default Re: How to Bleed the ALB System (samnt650)
I just get a bleeder I hook up to my compressor and it sucks like a mother! Always worked for me.
Old Jul 29, 2004 | 02:05 AM
samnt650's Avatar
Default Re: How to Bleed the ALB System (murtnabila)
When you do that, which part of the brake system were you bleeding off? I was under the impression vaccume bleeding would remove the regular master cylinder fluid and not the ALB master cylinder...
Old Jul 29, 2004 | 04:23 AM
Sliced Beard's Avatar
you bleed it just like any other brake system
Old Jul 29, 2004 | 04:39 AM
samnt650's Avatar
Default Re: How to Bleed the ALB System (dirtyd463)
The ALB is not "like any other brakes." It has a 2nd master cylinder and has its own pump. My understand is, it is far different than typical Bosch "in-line" unit. Afterall Honda did re-invent their own ABS system (didn't feel like royalty fee to Bosch?!?) I guess I should ask a better question, how do I activate the ALB pump? I am guessing I could use the internal unit to flush out the old brake fluid...
Old Jul 29, 2004 | 06:36 AM
JimBlake's Avatar
Friend of mine has an older Legend like that. The ABS has it's own reservoir & bleed screw, like my '95 Integra. Only that the bleed screw is just about impossible to reach. There's a special tool, which amounts to a bleeding bottle & hose, with a wrench handle, so you can open the bleed valve that you can't see.
It's pretty strange & I'm probably remembering it wrong. So you'll want to get your hands on a Helm manual. It's got a pretty good description of the system. He found a copy of the Helm manual at the library...
i97supratti
Apr 9, 2011 10:42 AM
dleccord
Acura TSX
Dec 8, 2009 06:21 AM
xiLLtegRax
Oct 20, 2005 12:35 PM
onyx00
May 18, 2004 05:13 PM
bamaTeg
Aug 6, 2002 03:37 PM
