Rod/Stroke D16's
R/S ratio on a Stock D16 is 1.52:1
Stroke is 3.54"
Rod is 5.39"
I have a project on my hands don't I
All you DOHC suckers better watch out.....it will be ready in about 6 years!!!!
Stroke is 3.54"
Rod is 5.39"
What is a mini me setup
I know for a fact I want to increase the deck height. So I can "stroke" then engine....purpose is a better R/S ratio. So basically I am going to have to rebuild the block anyway
Want to hear the good part? D16Y5.....yup VTEC-E! I can always swap the head to a VTEC and of course I want to be the fastest HX.
Edit: BTW do any of those sites have a webpage that you know of?
[Modified by Spade, 3:16 PM 11/28/2001]
Want to hear the good part? D16Y5.....yup VTEC-E! I can always swap the head to a VTEC and of course I want to be the fastest HX.Edit: BTW do any of those sites have a webpage that you know of?
DAMMIT.....okay....D16 has a 90mm stroke with like a 137mm rod.....increasing the rod lengh also increases the stroke......i just realized this.....Sigh, I need to find a way to keep stroke some what normal (close to 90 and get the damn rod lenght up).......a rod lenght of 157mm on a 90mm stroke is perfect however, it won't work with a D16 Crank. Fudge!
Okay.....if I increase rod lengh keeping the same crank I would need to have rods of XXX lengh to cover it basically stroking the hell out of the block.
My goal is a 100mm stroke that I will bore to 81mm. 2060cc!!!
[Modified by Spade, 5:05 PM 11/29/2001]
Increasing rod length will not increase stroke. It will increase dwell time at TDC and BDC. Also it leads to less extreme rod angles in relation to the crank, which results in less sidewall loading.
I belive a d15 motor is just a d16 block containing a crank with a shorter stroke, allowing the use of longer rods.
Yes, rod length does not affect stroke length. Take a b16b(CTR)for example. It is a b18c block, with a b16 crank, and longer rods, resulting in 1.6 liters of displacement. It has a r/s ratio around 2.x I belive. Good for prolonged high rpm use and power.
For now I am going to stay with the stock cam.....I plan on slowly building the car......springs and retainers, valves and guides, then port and polish, then cam.
After the head work is done I will go to the bottom end which I am looking into the sleeve and bore....want 81mm.
WhiteyW/AHonda
Sep 11, 2011 04:49 PM
805_Slow_Master_93EG
27
Apr 29, 2008 11:17 AM
big-cat
14
Nov 6, 2007 04:01 PM
JDMTuner4Life
Feb 24, 2007 07:29 AM
