Runnning Boost On H22A7
Old Jul 28, 2004 | 02:43 PM
modifications's Avatar
Default Runnning Boost On H22A7
i have just had my UK Accord Type R FI
had the car on the dyno before fitting the turbo nad got 214bhp @ flywheel
just had it done with the turbo fitted and was pushing 246BHP @ flywheel
i was looking at 300BHP.
the tuner told me that i needed to change the cams back to stock as i have high lift cams and it would cause over lap. and there not suited for boost
is this right, could it cause 50BHP loss with my piper VTEC22BP270 cams
Old Jul 28, 2004 | 03:03 PM
JDM.Accord's Avatar
Default Re: Runnning Boost On H22A7 (modifications)
I think you should be more worried about the 11:1 compression ratio then the cams
Old Jul 28, 2004 | 03:08 PM
fw190bvi's Avatar
Default Re: Runnning Boost On H22A7 (JDMAccord2nr)
how much boost are you running?? what are the other mods?? i hope youve built the engine for boost, or else that sucker is gonna blow......and yes, cams COULD cause that much loss, but its probably not the only problem
Old Jul 28, 2004 | 03:14 PM
Default Re: Runnning Boost On H22A7 (fw190bvi)
i have just purchased loads of goodies so i can sort the internals
like JE pistons 9:0:1 darton sleeves, eagle rods ect.
the turbo is running 5psi only and thats it no other mods so maybe its the cam set up thats casuing the problem. and i do have skunk2 adjustable pulleys and there really over the + ( advanced ) so im sure its the cams.
anyone else think its the cams
cheers for your help
Old Jul 29, 2004 | 08:52 AM
outkastcd5's Avatar
for a turbo application, you don't want too much overlap and i know the accord type r cams are pretty aggressive. i suggest that you pick up some h22a1 cams. what turbo kit are you using?
Old Jul 29, 2004 | 10:43 AM
its a drag turbo kit
Old Jul 29, 2004 | 10:44 AM
Nick H's Avatar
New User
Default Re: Runnning Boost On H22A7 (outkastcd5)
i think with using some either boost friendly cams, or maybe oem h22a cams, plus 6-7 psi, you could easily see 300 whp...good luck buddy...
Old Jul 29, 2004 | 11:29 AM
thanks guys
i was just worried that the company was ripping me off and the adivse they told me was rubbish.
bit thats cleared it up
Modified by modifications at 9:53 PM 7/29/2004
Spawne32
Oct 22, 2010 03:11 PM
twentyhurtz
Mar 22, 2009 10:41 AM
playalistic2
Jun 23, 2005 08:41 PM
99b18
Dec 27, 2004 06:32 PM
BSpec24
Dec 30, 2001 11:28 PM
